Question about Olympus DS-2 Digital Voice Recorder
Problems with memory on Olympus DS-2
I have erased all files on the Olympus DS-2, but it tells me that I have only 23 minutes and 36 seconds of internal memory left. When the physician tries to dictate it beeps to indicate that the memory is full? Have tried everything - Suggestions?????
I've had the same issue. The surefire solution is to go into the Sub Menu and FORMAT. It wipes the entire internal memory clean -- so be sure you've offloaded everything you need. You'll also need to reset the recording quality, if you have a custom setting, because it defaults to the highest quality. But you'll have all your space back.
I believe when files are deleted via computer, the DS-2 doesn't update itself to recognize the space is freed up. That's why data is gone but memory is not freed.  Good luck.
Posted on Apr 01, 2008
Correct full memory message on olympus 4000 recorder
You need to erase some files. If there are no files, the memory may be corrupted. From the menu go to sub menu, then format. This will clear the memory.
Jun 18, 2011 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
On my Olympus DS-2, although I have erased all my files the recorder shows that that there is little or no room for recording. This is the first time this has happened to me.
The amount of room available on the Olympus DS2 are determined by two things:
1. Avaiable Memory
2. Recording Mode
With that said, if you have formatted (erased) the files on the recorder and there is little recording room left, you will need to change your recording mode. I would recommend changing it to SP mode.
I hope this helps.
Feb 26, 2010 | Olympus DS-2 Digital Voice Recorder
Ds-30/ file recovery ?
Unfortunately this recorder is designed with flash memory and once you erase a file it is gone. There may be some companies (olympus is not one of them) that specialize in flash memory recovery but it is a very costly process and involves you sending the recorder to them to perform this operation.
You can go to google and search for flash memory recovery specialists.
Apr 16, 2009 | Olympus DS-30 Digital Voice Recorder
Olympus DS-30
sometimes formatting will reset the file number... format through the recorder..
Mar 04, 2009 | Olympus DS-30 Digital Voice Recorder
I don't know how to erase the recorded data on my DS-2 recorder.
Select the file, then press erase and follow the display. If you hold down erase, you should get an erase all option. Also you can select Format in the menu.
Nov 17, 2008 | Olympus DS-2 Digital Voice Recorder
Recorder Locked
The same problem "Read memory only". The best solution is : submenu/format/start
Good Luck
Mar 26, 2008 | Olympus DS-2 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus DS-50
No, you can't do this on the Olympus DS-50 , its not a dictation machine, you can do this only by Olympus DS-2300, DS-3300, & DS-4000 which they have the Editing Features : Insert,Overwrite, eraseing and Partial erase
Oct 26, 2007 | Olympus DS-50 Digital Voice Recorder
Olympus DS-2 Digital Voice Recorder Logo
274 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
