Question about Toshiba A75-S209 P4(HT) 3.06GHz 512Mb 60Gb 15.4" TFT Wireless LAN (PSA70U09700EBMODELA75S209) PC Notebook
Laptop When I start computer he turn him self off buy him self
  • Marinko Mar 07, 2008
    so how to fix registry error or driver problem is any web-site that you can down load the stuff.I am able to boot OS and computer work for about 5-15 minutes then turning itself off..
    Brigadier General:
  • 6,966 Answers
If your concern about turning itself of is a notebook or a laptop computer, it may be that the battery is not charged or the AC adapter/charger is not delivering power to the PC.
In some instances (including desktops) this could be because of a fault sensed in the hardware such as the CPU fan not turning, loose connection, dirty memory contacts. Additionally, if you are able to boot to the OS but thereafter shuts down, it is also possible for registry error, driver problems or even a malicious software or a virus.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 07, 2008
  • Louie  Role
    Louie Role Mar 07, 2008
    Hi again Marinko ,
    Appreciate the update.
    Since you are able to boot the OS and run for 5-15 minutes, then it is either a virus, a battery problem or a hardware issue. We can rule out the registry or driver possibility.
    Try running your antivirus for a full scan and clean/delete any found.
    On your Toshiba Notebook, try running it without the battery and see if problem persists. If problem is gone, you may need to charge the batteries at least overnight or have it replaced. Apparently, it is gobbling up all the power from the charger/adapter leaving nothing for the notebook to power itself.
    If even running on AC (without the batteries) and problem persists and there were no virus and malicious software detected, then it is possible a hardware issue within the notebook. This could be overheating (stuck up CPU fan), accumulated dust, memory or hard disk.
Acerlaptop isconnected to a dell monitor At first it worked well but then when I turn it on shows all the starting process but at the password screen isstuck on self testfeaturecheck. How do I fix it
As a laptop is involved, you may have bent a pin during connecting and disconnecting the monitor to the laptop. Check that out.
I assume you have tried cycling through the adjustment screens using the buttons on the monitor.
Before you try replacing hardware components, you might try "last good configuration" on your computer via F8 on start up.
Apr 07, 2015 | Dell Computers & Internet
White vertical band on screen of mac book
oooooim sorry either go and buy q new screen and replace it your self or buy a new mac
Dec 16, 2012 | Apple Mac Book Pro 13 In Laptop Computers
How can fix my laptop . it has turn its self up side dowm
The main reason for Windows system randomly because the computer has overheated. To fix this, if you have a laptop, then place the laptop onto a desk or flat surface to make sure that the air can get to it as designed and if you have a desktop, then you should take the side case off the computer and use a fan to cool air at your system.
Get technical assistance here if still the same problem is occurring.....http://www.vtechsquad.com/dell-support/
Jul 10, 2012 | Dell Inspiron iM50302792B3D Notebook
Packer bell laptop
Have you tried starting up in safe mode and going back to an earlier date also make sure its not overheating let it get some air
Jun 30, 2012 | Computers & Internet
My fan stopped working and i am facing overheating which making my laptop stop working and shut down suddenly
buy your self a laptop coolinng pad/table with built in usb fans your laptop will really appreciate it you can purchase these on Ebay ranging from $2.99 to $22
hope this helps
Jan 13, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
How to reboot my laptop (restart whole thing, start fresh, delete everything.)
of course format the hard drive to do this you need the software but under some bios systems they have self format options check your bios
Dec 29, 2010 | Compaq Presario CQ60-220US PC Laptop
Hp Pavilion DV 8000 (dv 8113 ea) heats up then hangs & turns off
I believe that would be the battery I would get a new battery that should solve the problem. When you use office or surf the internet that does not require as much power as playing games and watching videos. Just buy a new battery and that should solve the problem
Jul 18, 2010 | Compaq Presario CQ60-220US PC Laptop
It has problems getting it to turn on.. and when it does turn on, it suddenly turns off by itself after 10 to 15 minutes
It could be overheating (due to the failure of a fan inside the laptop) causing the computer to "self-protect" by shutting itself down.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Use the air to give a "blow-job" into every air-port in the laptop -- a layer of dust will act as a layer of insulation, preventing the computer from radiating the build-up of heat.
When you turn the computer on, listen for the fan(s) to start running -- put the hairs on your arm near an "exhaust-port" on the PC, to feel if the fans are blowing air out of the laptop.
Apr 08, 2010 | Toshiba Satellite M45-S265 Notebook
Hi, my computer screen won't turn on unless the mouse and keyboard are on. They don't ever turn on when the computer starts up and I'm thinking the computer 's reading type of thing maybe be wearing out....
If you are talking about when you turn your computer turns on, then i understand but anything else and i'd be lost. When you turn your computer on it goes thru a POST (Power On Self Test), where it checks the mouse, keyboard and all the internal components of the computer, it does not check to see if there is a monitor connected to the computer. If the mouse and keyboard are not connected to the computer correctly then the computer will error which means that nothing will be displayed on the monitor. If they are connected properly then the problem is in the computer its self, it may be slow or there may be problems with the display output controller. This sort of problem is easy to fix by buying another computer tower or box and transferring your information and hard drive contents over.
Oct 30, 2009 | Microsoft Windows XP Home Edition
USB device detection in Gateway Laptop
It sounds like your laptop BUS (usb power) does not have enough power to power the interface between the two. I had a couple of devices that did that. You may have to buy a SELF powered USB HUB in order to make them connect. The self powered usb will get it's power from and A/C wall outlet and not the laptop. You will connect you device to hub and hub to laptop.
Sep 18, 2009 | Gateway GT5432 Refurbished AMD Desktop...
Computers & Internet Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
