Question about Kitchen Ranges
My broiler keeps going out and I don't know where to light it at.
  • 833 Answers
If you are losing the flame on your broiler while it is in operation, get a service person. Your problem is bigger than just relighting it.
Posted on Mar 07, 2008
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
BROILER MAKES AIR BLOWING NOISE AFTER YOU OPEN DOOR AND IT RELIGHT
THAT SOUNDS LIKE THE GAS REIGNITING IN THE OVEN TO KEEP THE TEMPERATURE STEADY. IF IT MAKES A LOUD POOF SOUND PRETTY REGUARLLY ESPECIALLY AT A HIGHER TEMP, THEN IT SOUNDS LIKE THE GLOW BAR IGNITOR IS ABOUT TO GO BAD.
THEY ARE NOTORIOUS FOR BEING THE PROBLEM LATER ON IF OVEN DON;T HEAT UP, BUT TOP BURNERS ARE OK.
Jan 30, 2015 | KitchenAid KGRT607HBS Gas Kitchen Range
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
GE gas top and digital oven has broiler drawer near top with electric broiler inside. We are looking at this free-standing (stainless steel) stove here in Mexico and the manuals, and the website are in...
Yes appliances in the U.S. have different model numbers to their foreign counterparts.
JGB900SEPSS
The above, from GE's website, is the only thing I found as a gas stove with a baking tray. Are you sure it's a broiler drawer and not a warming drawer? Some stoves have a drawer to keep your food warm.
Aug 03, 2010 | Kitchen Ranges
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
