VCR Instructions for taping a show with a VCR on Charter Digital Cable
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    What is the manufacturer and model number of the VCR?
  • 8,596 Answers
Have not heard back. Make sure your connections are correct per users' manuals.
Posted on May 30, 2008
Black and white on my tapes
Is the vcr sitting directly on top of, or underneath the TV? If so, this could be causing magnetic/static interference, and that's not good. It's good practice not to have anything that uses tape near speakers or TV's. Hope this helps.
Another possibility is the signal you are recording is coming from a cable box/digital cable box/satellite cable box. Try recording using the RCA cable inputs and outputs, instead of 75 Ohm cable, if applicable.
Apr 25, 2010 | Toshiba M685 VHS VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Taping digital onto a vcr
You'll need to connect the VCR to the converter box and then connect your VCR to the TV. ou can get a diagram showing how to connect everthing at; there is a section with publications that has a document on how to hook up your VCR to tape the show your watching or watch one show while taping another.
Mar 14, 2009 | Insignia Digital-to-Analog Converter for...
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Taping TV shows
You need to have an antenna in (from TV antenna or cable). Set the VCR to that channel and press RECORD. Or use the on screen menu to set up the recording time/channel
You really need to have a manual to find the step by step instructions for your VCR. Go to this website and search
for a VCR manual from Sharp. I was there and did not find the exact manual.Download a couple of ones that have similar model numbers and follow the process.
Or call Sharp and ask them to fax/email you a manual.
Oct 31, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
