Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
ThinTwin cabinet access
Gotta replace the water pump for my ThinTwin Whirlpool. How do I get inside the cabinet to do it?
    President:
  • Whirlpool Master
  • 2,651 Answers
A little awkward atfirst but shlould be a problem. remove the angular panel along the rear of hte washer top youll see two brass clips an inch in on both sides, with a screwdrier "pop" these clips off, and if i remember correctly there are (2) 5/16 screws directly behind them (sorta on the frame of unit just below the rear lip of the top) the main top then will slide toawrd you and rigth off. a screw secures the front panel on both sides adn it too lifts up and off. acess to pump is right there. reverse order nad your good to go.hte brass clips will SNAP right back in place when lined up correctly
Posted on Mar 07, 2008
My whirlpool h2 low wtw4950xw wont spin
If you hear the motor running but only the water pumps out, you probably need a new coupler. These are very cheap and easy to change, if you're mechanically inclined.
Getting into the cabinet is a matter of two screws, two clips, a wiring disconnect, and enough space to tilt the cabinet off the base of the unit and set it aside.
Once inside, you'll see the pump in the front, mounted on the motor. The pump is held on with 2 clips, and can be swung aside without disconnecting the hoses. The motor is held on by 2 clips and 2 screws, and has one wiring plug. Once it's out, you can see the coupler, which probably has had the pins sheared off the plates, and some rubber remnants. Carefully pry off and replace all the parts, being careful to align the pins when re-installing the motor.
Re-assembly is the reverse of dis-assembly. You can test with the cabinet off if you place a small jumper wire across the pins of the plug that hooks into the cabinet for the lid switch.
Nov 20, 2013 | Whirlpool Washing Machines
Won't fill with water, will spin
Turn the water off and remove the hoses from the machine. Check for clogged screens, pry them out and wash them then re install the screens and retry. To replace the water valve is pretty easy. Removing the cabinet will be what ya gotta do. Their are plenty of videos on youtube which show how to replace a water valve on a direct drive washer. Like this one
Paw Paw's (me) service manual
Apr 22, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not turn on, here a buzzing sound
you have to unplug the power cord, remove the cabinet, at the lower center there is the water pump, remove it and move it out or the way from the motor. put back the cabinet and try to turn it on. if it comes on then you have a blocked pump or a piece of clothing inside holding the pump impeler. remove cabinet, get some towels and remove and inspect iside of pump. use a big flat head screwdriver to move pump with it. if it not move replace pump. if you find clothing inside remove and install and run washer.
Feb 15, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer began leaking. what should i check for?
check the water pump. you will need to remove the cabinet to see. once you can get the cabinet off, it is usually easy to replace the pump.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer will not fill with cold water
Hi Pekahs,
Your inlet valve has gone on permanent strike and has gotta be replaced. The part number is 285805 and can be found at a local appliance parts retailer or you can plug that part number into a search engine and price shop on line. Follow the instructions in this video for access to the cabinet and valve....
You'll see the valve on the right hand side. It's a very simple repair, but if you have any more questions just write back, OK?
SG
Apr 07, 2009 | Whirlpool Washing Machines
Howdo i get the washer cover off a thintwin whirlpool washer tha
the timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Feb 15, 2009 | Whirlpool LSB6200PQ Top Load Washer
Whirlpool LSQ9500LQ0 will not drain water
Access to the inside on this washer will require taking off the whole cabinet.
1. Remove two screws on the back side and on each end of the control panel.
2. The whole control panel will then pull forward then flip it back out of your way.
3. There are a group of wires coming from the control panel going down to a single plug, unplug them from the main cabinet.
4. Remove the two large brass colored clips on each side.
5. You can now remove the whole cabinet.
The water pump is in front and secured only by two clips top and bottom.
Dec 26, 2008 | Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
