Rank: Apprentice
Rating: 0%, 0 votes
Due to law in the USA Jensen made a safer way to drive.
So when your Ebrake is off your head unit will display a msg saying to do you ebrake manuever. So there is your answer to bypass this, there is also a code but for every unit it's different.
Just by a on, off switch and conect the pink to one end and another ground wire to the other end of the switch. Then your'e done. Just press off for two seconds and then press on for two, do this twice and you will be ok. If you have the code is much better. This is the alternative. Greetings from AUA
