Question about Refrigerators
Evaporator not defrosting
Evaporator icing up, wondering if it is the element around it is bad,
how do I check..
    President:
  • Refrigerators Master
  • 2,651 Answers
Element can be checked by continuity test, you should have continuity through it. theres a defrost thermostat clipped to the top of the evap also common to go bad.. closes at specific temp ( written on side of thermo) allowing heater to come on, if it remains open the heater wont be energized
Posted on Mar 07, 2008
Why is it switching off and defrost and timer
The purpose of a defrost timer is to periodically run the defrost element every 6 hours or so for about 25 minutes - which stops ice building up around the evaporator - the ice melts and runs through the drainage system which usually is evaporated by the condensor.
Jan 05, 2015 | Refrigerators
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
Frozen evaporator coil
if the evaporator coil is frozen over,then most likely the defrost terminator is bad its located on the top of the evaporator coil and is about 1" round,to test it it needs to be below 15 degrees as this is a bi-metal switch operated by temperature,it will show close to zero ohms when its cold if its good,otherwise the defrost heating element can be open its located under the evaporator coil,but its a calrod element and they usually dont go bad,you can check this with an ohmmeter also and will have anywhere from 20 to 75 ohms,if these are both ok,then the defrost timer or ADC automatic defrost timer can be bad depending on which system your unit incorporatesl
Aug 25, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Amana Model# ARS2365AC The freezer is not keeping the food frozen and the refrigerator is not as cold as it use to be. Both control dials are on 7 the maximum it can go. Thank you for all your...
if the rear wall inside the freezer has ice build-up on it then the defrost isnt working,remove this panel and check evaporator coil if its iced up the evaporator fan cant blow the cold air thru this coil,defrost it with a hand held hair dryer,then check the heating element located below the evaporator coil for continuity then check the round defrost thermostat on the top of the evaporator coil,note,this part needs to be tested below 32degrees to test good above that temp it will show open or bad
May 29, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Icing up around coil
either its the defrost heater under the evaporator coil or the defrost control in the refrigerator compartment is defective and not powering up the heating element mentioned above
Jun 16, 2010 | GE CustomStyle 21.5 Cu. Ft. Side-by-Side...
Model RCM24F GB. Why does the freezer section ice up when it is supposed to be frost-free. It takes ages for the ice to melt and makes a mess with ice melting
either the defrost heater element is bad or the control that feeds power to the element is bad,you need to open up the evaporator area and check the element for continuity,if its good,then its probably the defrost control,being either a timed or adaptive type
Apr 13, 2010 | Freezers
I am also getting massive frost build up on the freezer side
depending on the model, 1-5 years. 5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged 5. defrost cycle not functioning properly if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it?ll go into defrost, but it will either tell the timer that it?s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element). defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 11, 2009 | GE Refrigerators
Fan runs, but does not cool?
Sep 11, 2009 | Magic Chef Refrigerators
Cleaned the coils but freezer not freezing and inside not getting cold what is wrong
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
