Altec amp. Altec Lansing 1594A amplifier is poping fuses and am unable to locate schematic or information on the RCA D40934 transistor. Pat
SOURCE: I'vebeen given an Altec Lansing
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Posted on Nov 13, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
petraman7
  • 1175 Answers
SOURCE: What kind of fuse do
http://www.alteclansing.com/images/user/VS4221_MAN.pdf
Posted on Jan 22, 2009
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
I need a wiring diagram fo computer speakers,Altec Lansing Multimedia FM501011854B
You mean the internal schematic, as in diagnosing / repairing a fault?
Google is your friend.
Look in images section of your browser after entering "altec lansing FM501011854B, schematic".
OEM's / Original Equipment Manufacturers as a rule usually don't post full circuit diagrams of their products on the web, to avoid competitors pirating their products.
But you may come across the schematic on a site that stocks service /repair manuals.
Otherwise search for Altec Lansing (Consumer Electronics) website.
Oct 13, 2017 | Audio Players & Recorders
I need a circuit schematic for Altec Lansing amplified speaker system 121
You can always try the manufacturer but I would not hold my breath. Try to google it - that is a better choice since perhaps others have also had hassles and ................
Aug 09, 2015 | Altec Lansing Audio Players & Recorders
Altec Lansing BX1120 Computer Speakersrepair
You don't need theory of operation. Altec systems don't publich the schematics so your best bet would be component level work with an ESR meter, an oscilloscope, transistor tester and DMM.
Oct 18, 2017 | Audio Players & Recorders
Altec mx 5021 schematic diagram
We may not be able to find yet your free schematic diagram,
But if you insist on repairing your computer speaker,
• Open it up , and look for possible causes of
symptoms .
• Check on line for the datasheet of the amplifier,
• Use a multimeter to check for open and short
circuits.
Here is guide when repairing similar Computer Speakers
http://www.fixya.com/support/r4008719-diagnose_not_having_audio_right_channel
Jul 26, 2012 | Altec Lansing Audio Players & Recorders
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Apr 14, 2009 | Altec Lansing VS3251 Speaker
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec Lansing ACS 54 Transistor Question
hi, I stay in india. there is a market out here near my place where u get old stuff. the other day a guy was selling this woohper . i bought it. it does not have the satellite speakers. how can i help u out
Nov 02, 2007 | Altec Lansing ACS 54 Computer Speakers
172 people viewed this question
 Grubhead
Grubhead
