Question about RCA RS2640 CD Shelf System
Buzzing noise whenever i try to play any kind of audio whether it be CD, AUX, Radio, or Cassette. please help me and if it needs a new component if you could offer a link to a website were it could be purchased. thank you for any help you can give = )
  • 518 Answers
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
First, nobody has used the Cassette Adapters since Milli Vanilli got caught Lip-Synching and Mike Tyson got knocked out by Buster Douglas. U can buy a new radio on ebay for under $30 that has what is now called an "Auxiliary" cord or "Aux" cord.
Second, if u are set on keeping that stone-age paper weight u call a radio (I had one of these too, up 'till 2 yrs ago), try to play an actual cassette tape. See if it gives u the same results that the adapter gave u. If it does then the problem is in the radio and it might cost more to fix than it's worth. If it doesn't give u the same results, then try to find what is referred to as a "cassette deck cleaner kit." After u follow the directions on the kit try the adapter again. If the issue continues, then try a new adapter. By this point u are probably going to be 1/2 way to the $30 it cost for a new radio. Short of that, there isn't much else u can do unless u want to open up the radio but again, not worth the trouble.
Good luck.
Aug 13, 2015 | 2005 Honda Accord
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Noise in auto stereo
check all ground if still buzzing buy a noise filler
Oct 06, 2009 | Sony CDX-RA700 CD Player
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
Recording to Cassette
Most Audio Shelf System follow the same procedures for recording. You need to select your source as if you will just be listening, AM, FM, Aux etc. Thereafter, you need to press Record (sometimes with PLAY) to start the recording. Normally, it will record whatever source is playing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 23, 2008 | Audio Players & Recorders
CD/Aux play
for the "AUX input" source put it in standby mode and hold menu... scroll down to "aux in" and turn it on by pushing right
Nov 10, 2007 | Kenwood Excelon KDC-X789 CD Player
Something spinning
1. Check all cable connections to make sure they're secure. 2. Replace the cable connecting the CD unit to your receiver. 3. Clean the contacts on the player and receiver with electronics-grade contact cleaner. good luck
Jan 06, 2006 | RCA RS2041 CD Shelf System
RCA RS2640 CD Shelf System Logo
298 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
