Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp connector I replaced the lamp today, but when reinstalling the housing the receiving connector inside the TV popped out of its postition. I then opened up the back of the unit to reach in, in order to reconnect to the lamp housing connector. Now I only get sound, not picture. The lamp is not coming on and its not the bulb itself because I tried placing the old bulb back into housing with same results. It has to be something that happened when the receiving connector popped out. The fan is truning on, i can hear it. I am so lost on what it could be though.
  • ybor_knight Mar 06, 2008
    Also...After the TV plays for a couple minutes (volume only) it cuts off with a red lamp indicator light.
  • ybor_knight Mar 12, 2008
    Thanks for the advice. I managed to fix it myself. Upon further investigation, the metal clip that held the female connector in place inside the TV was bent from having the connector pushed out of it. Apparently when I was going in through the back of the set in order to connect the lampa housing by hand, the bent prongs of this clip were not allowing me to fully engage the connection. Once I removed the clip, the connectors made full contact and the lamp came on. It will be a little of a hastle changing the lamp from now on because I will have to open the back of the TV in order to connect, but problem solved and I saved $300 over sending out for service which would have probably taken 2 weeks.
    Genius:
  • 1,153 Answers
Do a self test diagnosis by pressing the menu and device/input buttons on front panel for 5 sec and you will see a seq. of blinks followed by a short pause and then more blinks. count the first set and last to give you the error code.
Posted on Mar 11, 2008
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Standby lamp flashes red
Had the same issue today when I replaced the bulb with housing. Did you try to turn on the TV without attaching the housing door? That was my problem...tried to see if the new bulb worked without going through the motions of screwing on the door. I believe the housing contacts are not making a good contact. Try taking the housing out and reinstalling it firmly in place and definitely screw in the door firmly as well. Perhaps it will work then. Advise...
Aug 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Where is the lamp housing unit & how do I remove it?
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lights flashing and no piture or sound
I had the same problem a little over a year ago. It was the lamp. It needed to be replaced. I hope you have the extended warranty.
Jan 08, 2008 | Hitachi 50V720 Television
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
Tv lamp replacement
I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
I just replaced the lamp and saved $130.
I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
re-attach all the screws and slide it back in.
It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
Oct 27, 2007 | Sony KDS-R50XBR1 50" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
