Question about Berkeley Forge G-PH001PSS Open Flame Patio Heater
Will not stay burning
When i light the burner it will stay burning for about 2 minutes and then shuts off and i am not able to relight it for about 5 minutes.
  • AutoChuck Mar 29, 2008
    I have the same problem with my SR-1001. I took the gas control apart and found the mechanism controlled by the thermocouple does not pull in when the thermocouple is heated. The shaft sticks. There is a coil of wire on two poles and the thermocouple isn't inducing enough of a current in the coil to get a magnetic field to pull the shut off down. I cannot find another gas control or parts. Thank you Home Depot for not standing behind the products you sell.
  • Kashif Ahmed May 11, 2010
    What? Please explain the whole problem.
I think i may have solved it. i heated the thermal couppling and very gently bent the tip about 45 degrees. it has been running about an hour now i'll let you all know if this fails but so far so good
Posted on Sep 06, 2008
My fireplace lights but shuts down within a minute and pilot goes out. Pilot will relight but Fireplace will not relight for a while. Keeps doing this, will sometimes stay on. Does this describe enoug
Sounds like a sensor problem or a gas blockage. Get a gas expert to look at it. Gas is dangerous and can cause severe burns or explosions resulting in loss of life and property.
Oct 03, 2014 | Heating & Cooling
New Reliance gas water heater won't stay lit
There is a sensor that shuts off the gas to the burner if a flame isn't detected within a few seconds. It will usually look like a tube that extends into flame of the burner. It may be defective or it may just need to be repositioned so more of it is directly in the flame.
Mar 17, 2014 | Reliance Water Heaters
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
PILOT & BURNER WONT STAY ON< ABOUT 2 to 5 MINUTE THEN GOES OUT, BUT WILL RELIGHT AGAIN
Pilot tube is probably restricted. Try blowing it out with compressed air.
Oct 15, 2010 | Heating & Cooling
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Heating & Cooling Logo
303 people viewed this question
Top Berkeley Forge Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
Are you a Berkeley Forge Heating and Cooling Expert? Answer questions, earn points and help others
