Question about Pioneer VSX-1014 Receiver
Mcacc light is blinking and receiver will not turn on
I am having trouble with receiver
  • 1 more comment
  • rhogn May 13, 2008
    I have the same problem, after an AC power interruption. Any solution yet, or should we just buy new receiver?
  • gofastest Nov 29, 2008
    Mine too after a power surge. A company checked it and told me that it was total loss. Pioneer VSX-D812x
  • Anonymous Mar 26, 2014
  • 3 Answers
Press the ENTER + VIDEO2 buttons on the front panel of the unit for 2 seconds. The unit then comes back to life! Lifesaver... I've been there... Works for VSX-1014, mine at least... ;)
Posted on Dec 04, 2008
3 Suggested Answers
SOURCE: MCACC Light Blinking and reveiver
If you hold ENTER + VIDEO 2 for 2 or 3 seconds it should work ... not a factory reset so proceed at own caution!!!
Posted on Jul 05, 2008
Bulldog AV
  • 52 Answers
SOURCE: my pioneer receiver will not turn on and the mcacc
Try a reboot. Hold Enter + Video 2 for 3 seconds.
It could also be a short. Check to be sure your wires are not touching and that volume levels are low to start.
Posted on Nov 23, 2009
Tip
How to disable "Perform an automatic send/receive when exiting" in Outlook 2007...
If you are having trouble with Outlook closing it is possible that there is a problem with Outlook its self. However one of the things that I have found is that the "Perform an automatic send/receive when exiting" option is turned on. Below is the steps to check to see if this in enabled in Outlook 2007.
1. Click on Tools then Options in the menu bar.
2. Once in Option click on the Mail Setup tab
3. Click on the Send/Receive button.
4. Make sure "Perform an automatic send/receive when exiting" is unchecked
5. Click Close
6. Click OK
Note normally in a corporate environment this is not turned. If "Perform an automatic send/receive when exiting" was already disabled and you are still having trouble with Outlook closing you may need to reinstall Office on the computer.
on Apr 17, 2010 | Microsoft Office Outlook 2007 for PC
Speakers work at low volume. Around -39 db, receiver shuts off.(protection mode) Tried moving speaker wires, alternating red and black. No go. When powered back up, display says ck sp wires. Once I...
Decibels correspond to the output voltage being sent to the speakers. In your case, the voltage is reached at -40dB is the threshold that causes whatever is happening to operate the receiver's protection circuit. You might have a bad speaker, with a voice coil that shorts at the higher voltage. Below that level it's okay, but at the magic point the insulation breaks down, and that's when the receiver sees trouble.
You might try connecting only one speaker at a time using a short length of wire other than your current ones. If the trouble occurs on one speaker only, you've found the culprit. If the receiver operates normally on each speaker, try reconnecting one speaker at a time to determine if one of the speaker wires may have a short somewhere. There might be a weak spot in the insulation, not causing any trouble until the voltage is high enough.
If the receiver still goes into protection with just one speaker, there's an internal problem. Some part in the amplifier may be breaking down at that voltage. Or a part value has changed, causing the protection circuit to kick in even though there's really nothing wrong. Bad solder connections may have developed. Unfortunately, this kind of problem usually needs the services of a shop with the equipment and circuit information to figure out what's happening. If you can find a Yamaha-authorized warranty servicer, they might already know some typical causes if they've seen units with the same trouble.
Try the speaker test first. Then let a shop tackle the receiver if it looks like that's where the fault is. Good luck and thanks for using Fixya!
Jun 03, 2011 | Yamaha HTR-5830 Receiver
Can't send or recieve faxes
Having trouble receiving faxes?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000018476&Sympt=I+am+having+problems+receiving+faxes.+What+can+I+do%3f&Model=1292&ProductGroup=5&Keyword=fax&ProductID=MFC7840W
Having trouble sending faxes?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000018532&Sympt=I%27m+having+problems+sending+faxes.+What+can+I+do%3f&Model=1292&ProductGroup=5&Keyword=fax&ProductID=MFC7840W
I hope this helps!
Dec 11, 2009 | Brother MFC 7840W Printer
No sound connecting mp3 player to receiver.
my mp3 player doest have any sound t all
Oct 27, 2009 | Onkyo HTR500 Receiver
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Distortion using rear speaker interfaces.
yea get new speackers or u have a very low quality wire also can bet out of eq
Apr 02, 2009 | Pioneer VSX-1018AH-K Receiver
Having trouble fitting receiver in canopy
if your receiver is separated from fan place it inside sheetrock !
Dec 21, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Pioneer VSX-1014 Receiver Logo
743 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
