Question about Sony PlayStation Portable (PSP) Console
Psp how to get on to the internet using wifi
I have the wireless router all set up for my archos and it works on that but when i come to use my psp it askes me to switch on the wlan and i dont understand it also askes for a ssid dont know where to find it and also a connection name help me please.
  • Rogie99 Mar 07, 2008
    I dont know how to on the SSID
  • djwilder08 Nov 19, 2008
    cant get on because there are no good connections
Hmm i cant even find out how to get wireless internet for psp slim. also i hav no idea how to get the lights next to memery stick to turn on. wat is a SSID any ways?
Posted on Apr 03, 2008
  • 97 Answers
Ok, the wlan swith is either on the top of psp if u have da slim if you have the old version then its o the side. the ssid is the name of ur internet connection ex.(linksys etc.) and some of the connections are either secured or unsecured. the secured connectipoons require passwerd. if you have a wireless router then scan 4 a connection and look 4 urs and connect.
Posted on Mar 19, 2008
**** it ! ******** walan
    Problem Solver:
  • 4 Answers
Well the walan in the swith on the side it is similar to bluetook the wun on the left of the psp
SSID i think is the name of the netwirk u want to connect to
Posted on Mar 18, 2008
Manfiodhslfksdhklfdnsklcvnsdklvnklscvnklscnvklscnvlksdnvklsdnvskld
Posted on Mar 07, 2008
Wifi says connected but no internet
hello
To make sure that the ARCHOS can recognize the presence of the WiFi access point, go to Menu > Settings > Wireless controls > WiFi settings and then see what is listed under the section "Wi-Fi Networks". One or several WiFi access points should be listed.
If the access point you want to connect to is not listed, then it might be
• Because the router/modem is not switched on.
• Because the router/modem access point is set to not broadcast its identity (even though it is available for use). Ask the manager of the WiFi modem/router to temporarily enable the identity (SSID) broadcasting. To do so, one would have to go into the settings of the router/modem either by using the web browser or a special application program that came with the router/modem. Search for a setting that has a name something like "Hide SSID" and make sure it is off. Once this is done, the ARCHOS should recognize the access point and be able to connect to it. The ARCHOS just needs to connect once and it will "know" this access point - even when it is later "hidden". The WiFi router/modem can then be set back to "Hidden SSID". In general, hiding the SSID of your modem/router is ineffective as a security measure so you might as well just leave it on.
please send me 4 thumbs up
Jul 20, 2011 | Archos 7 HOME TABLET V2 8 GB Hard Drive
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Dec 17, 2010 | Archos 28 Internet Tablet
Can not get psp to connect to wireless router
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Steps Turn on your PSP.
Enable wifi by flipping the WLAN switch to the on position.
Select network setup from main menu, select network settings (press "X").
Select infrastructure mode.
Create a new connection.
Select scan to look for your WiFi network.
otherwise if you know all of your network settings, you can do it maually
Select your wifi networks SSID.
Enter your security settings(if applicable)(WEP, WEP TKIP, Shared Key).
Select "easy" in configure network settings to obtain ip address.
Confirm the settings.
Test the connection.
Go back to the main menu, select the broswer & enter a web address (www.google.com etc.). Your PSP's internet is ready to be surfed out wirelessly.
the psp, unless you have a hack installed, will not be able to browse sites such as youtube, or facebook, or twitter because they require flash/java/enhanced memory[this is not the memory stick]it can however use facebook mobile or myspace mobile by typing in m.facebook/m.myspace.com -- Tips:
  • You may have to do this every time you are in a new area or surrounding that has wifi hotspots
  • Go to www.youtube.com for tips, tricks and hacks.
  • Go to your favorite cheat code website for cheat codes.
Things You'll Need
  • Sony PSP
  • Internet
  • Wireless router
Jun 11, 2010 | Sony PlayStation Portable (PSP) Console
I need help connecting to the internet with my psp
Connecting the PSP to the internet is pretty easy once you get all your settings in place. Here’s how to connect the psp to the Internet. You will need a wireless router in order to connect the PSP to the internet or you could “borrow” your neighbours wireless access although it’s better to have your own. Wireless routers are very cheap nowadays you could find a good one for about 30 for 50 bucks.
  • With your Psp turned on go to the “Settings” in the menu (scroll to the left)
  • Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
  • Select “Infrastructure Mode” and hit “X”
  • Select “New Connection” and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose “Scan” and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • When the PSP finishes scanning you will probably have a few different wifi connections. SSID is the name of the connection, the Security column tells you whether or not the connection is password protected, and the last one is the signal strength the higher the better
  • If you want to borrow your neighbors unprotected wifi select a connection with “None” in the Security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
  • Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached “Network” and go down to “Internet Browser” and hit “X”
  • Your browser will appear, select the little square box to enter the web address, play around with the different options. Have fun with your PSP online
Mar 08, 2010 | Sony PSP-3000 Silver Console
How 2 connect psp go 2 net via home network and mobile wireless do i need wireless router
to connect your psp go to the internet you need a wireless router to emit a wifi signal to connect to the psp, if you are using you phone as a router connect it via bluetooth.
Yes you need a wireless router or a blueooth enabled phone.
Feb 28, 2010 | Sony PSP (Piano Black)
How can i take internet in my psp
The PSP is more than a gaming platform. It has WiFi connectivity, and that means that setting up PSP Internet is possible, just like on any computer. The WiFi feature is intended primarily to be used for upgrading software and for downloading games. But you can go several steps further than that, and it isn't difficult to do either.
You need to have access to an Internet connection first and foremost. This can either be at home where you really need a wireless router, or use you can try accessing a public WiFi hotspot like your local Starbucks or wherever.
The most common home set up is an Ethernet cable running from the computer to the DSL or cable modem, which in turn is connected to the telephone line. By installing a wireless router between the computer and the DSL or cable modem, you should be able to connect your PSP to the Internet too.
Of course, setting up PSP Internet isn't just as easy as that! And if you don't have a home Internet connection of any kind, then you'll have to find a WiFi access point that will allow you to connect. This should be reasonably easy in most medium to big cities. But if you live in a small one-horse town way back in the sticks, then maybe, maybe not.
The PSP also needs WiFi access that is the 802.121b wireless networking protocol.
Hmmm... I know what you're thinking. You're thinking, that's it! Way too technical for me! But hold on, it isn't.
This protocol is, thankfully, the world's most popular one. So the chances are excellent that if you find a suitable public WiFi access point, it will be the good old 802.121b wireless networking protocol.
Most people find problems when they come to the more technical bits. Finding the Network Settings, choosing a New Connection, making sure it's Infrastructure Mode - it's all too much for many who try it. Then there's the WLAN Settings to access, a scan to implement for an SSID of any access points nearby, hoping it's not using WEP encryption!
Time to think again...
This isn't rocket science, though some may think it is.
You need, in this order:
1. To have some kind of a proven Internet connection.
2. Select the Infrastructure Mode in Network Settings and start a New Connection.
3. Access the WLAN Settings and initiate a scan to search for suitable access points.
4. Select a suitable access point that is not encrypted.
5. Test the Connection and enjoy!
Sep 10, 2009 | Sony PlayStation Portable (PSP) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
My Archos 605 80gb cannot find my netgear wireless thingy!!!!
I had the same prob with a LinkSys. Puzzling for sure. Finally, I went to a Crystal restaurant (hot spot) and it connected. So, I knew it wuz my router. Finally stumbled on to the prob. I had to key in the 605 MAC address in the router table. Now, it works beautifully. You can find your MAC address under "Settings." Hope this helps!
Jan 18, 2009 | Archos 605 WiFi Digital Media Player
Archos
Have you tried username 'admin' and password 'password'?
These are for the actual router.
If it's the wep/wpa wireless encryption password, then you need to go into the router's domain page, it'll be something like 192.168.0.1 (or 192.168.1.1 or 192.168.2.1 or 192.168.0.2) and enter admin and password, and then, usually under the Firewall menu, it'll say Reset Factory Settings. You can reset it and your wireless network should now be unsecured and you'll be able to connect to the internet wirelessly with any device.
Hope this helps
Chris (ziraffa)
PS You can also go back into that page and set new passwords for encryption and also for passwording the actual router too.
Write them down this time! :)
Dec 28, 2008 | Archos 704 WiFi Digital Media Player
2wire sbc wireless modem connection
      Dylan,      I don't know who your ISP provider is, but I am using BT and had to change to a Belkin modem so that I could connect Archos 605 wifi and Palmone.  Had the same problems as you have, which have disappeared on installation of Belkin modem,
                             Samcalm
Jan 05, 2008 | Archos 605 Digital Media Player
Sony PlayStation Portable (PSP) Console Logo
153 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
