Maytag se1000 washer
I have a maytag se1000 stacked washer and dryer. When i turn it on it fills normally but when the wash cycle starts the whole tub rotates instead of the agitator working back and forth. on spin cycle the tub rotates the other way and pumps the water out normally. I suspect the transmission has problems or a bushing or bearing is locked between the tub and transmission. does this seem probable to you?
Thanks; Paul
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds like the brake is not engaging properly(locks the tub for agitiation) wouldn't say transmission just yet, don't know the age but probably a few hundred dollar repair, i would recommend a maytag guy to do the repair, requires special brake tools and such,
Posted on Mar 07, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Water still in below the inner drum
Its not water it's a balance ring that is filled with fluid.
Mar 23, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Stacked washer it fills up but it doesnt cycle
Hello, sounds like you have a faulty lid switch . The lid switch is located behind the tub in the right rear, the front panel and the washer top panel have to be removed to gain access to the switch assembly. good luck
Dec 22, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Pump turns on while filling
if it start draining while is filling the water. you need to ck the drain house. it is too long in the drain you need to pull it out little.
Feb 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
426 people viewed this question
Top Washing Machines Experts
