Tip & How-To about Coffee Makers & Espresso Machines
The procedure is as follows:--For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
This will help.Good luck.
