Question about Sanyo PLC-SU50 Multimedia Projector
Projectors screen turns yellow,on and off,after awhile has been looking white
    Champion:
  • 205 Answers
You are describing Color Decay. Welcome to the world of LCD projectors. The blue device is the first to go, thus the yellow fringe. You must have about 3-4000 hours on the projector. Replace the product with a dlp product and it will last a lifetime, or until you want something with newer features.
Posted on Jul 07, 2009
2 Suggested Answers
SOURCE: yellow tint square inset 2 projectors!
The blue polarizer "in" is burnt. You need to replace it.
Posted on Aug 09, 2007
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
I have a Christie LX100 Projector when projecting a white image there is some yellow tint. Is this something that can be fixed?
If the yellow tint is uniformly over the whole screen then try changing the video colour tint, hue, phase and other chroma related settings in the menu.
Apr 10, 2011 | Christie RoadRunner LX100 Multimedia...
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
I have the same problem as someone else has posted on this site. When I start up the projector, x1a, it goes directly to a faint white screen without any button response. With or without a video source...
replace the colorwheel. part # 525-0144-00. you can get it through av solutions in ny. www.avsolutionsny.com it's not that difficult to replace, but if you are unsure about it, you can send it it to them to repair as well. they are an infocus service center.
Nov 15, 2009 | InFocus X1a DLP Projector
Ibook g3 av port needs possible replacement?
Your yellow tint issue can be from two different things. One, it can be a setting on the projector itself. Two, or can be the screen you're projecting your image onto. Your projection screen needs to be very white to get good results.
Jul 06, 2009 | Apple iBook G3 Mac Notebook
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Yellow tint square inset 2 projectors!
swounds like a default setting has been changed .. Try finding in the manual how to do a master reset to factory defaults
Apr 19, 2006 | Sanyo PLC XF45 Multimedia Projector
Sanyo PLC-SU50 Multimedia Projector Logo
231 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
