TV won't stay on, Standby blinks 10 times
My Sony KDP57WS655 standby light blinks 11 times when first turned on. The sound comes on briefly but no picture; then the TV shuts off again. After that the standby light rapidly blinks 10 times, pauses, blinks ten times, and repeats.
There are no authorized repair personnel within 100 miles of where I live and the only two within my state told me I would have to bring the TV in myself for diagnosis.
All I want to know right now is what error message is being indicated by the 10 blinks and what part needs to be repaired or fixed so that I can possibly save some time. Does anyone have information on this?
Its sort of silly, but my father got behind the tv and smacked it. The error message went away, and the tv is working fine now.
It wasn't easy for him to get behind it though, it's rather tall and weighs 234lbs.
I did manage to find a pdf file of the repair manual for this model at Techlore.com.
Posted on Mar 09, 2008
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Trinitron KV-27FV310 won't stay on, standby button flashes around 10 times, help please?
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Jun 18, 2012 | Sony FD Trinitron WEGA KV-27FV310 27" TV
My Sony KDP57WS655 standby light blinks 11 times when first turned on. The sound comes on briefly but no picture; then the TV shuts off again. After that the standby light rapidly blinks 10 times, pauses,...
laisecorp,
You have a problem on the "D" board. If you understand electronics and soldering you should check transistor Q8014 and Q8013 for shorts, leakage or bad solder connections. If you find any problems replace the transistors and also check/replace R8051 and IC8005.
If you are not good at soldering or fixing electronics go to http://www.encompass.com and purshase the board, part number A-1065-548-A. The board is $150.00 US plus shipping.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 20, 2010 | Televison & Video
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Televison & Video Logo
601 people viewed this question
Top Televison & Video Experts
