Question about Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard
Dead new motherboard
Hi I have got a new motherboard and cannot get it to power up, I am sure its me as the supplier have confirmed it works , I have plugged in the power supply cablesbut am not sure what other the case leads I need to plug in as minimum to get it to start , in the past have installed P4/P3 motherboards and you do need to connect any case cables to get it going , and also usually you get a small light on the motherboard , I am using power supplies out of P4 machine which do work with P4's any ideas
Alan
  • Alanuk Mar 06, 2008
    Hi , yes its 20 pin power supply and it does work as I have taken it from a working P4 2.4
    So do all the case ones have to be connected before it will start then?
    Alan
    I did connect the power one , but do I need any others as a minimum , e.g. reset , speakers etc or anything else to just get the fans spinning so I know there is life?
    Alan
    Genius:
  • 1,019 Answers
Hi alan,
You really need the Motherboards User-setup manual.
if you have,nt got the pwr from case switch connected to the header on mainboard, And possibly reset switch you won,t power it up. You should have a 10-12 + pinheader on the mainboard, which usually houses reset-mains on/off/speaker et,c. these have to be connected correctly. either a magnifying glass, they should be marked i.e Spkr=Speaker. Pwr=Power. Hdd led= Hard-drive led. et,c. also ensure you have the 4 Pin power connecter on the board, usually by the CPU.
Mike @ Compurepair.
Posted on Mar 06, 2008
  • Mike Waldron Mar 06, 2008
    Hi Alan,
    Sure if you have,nt got the power switch from Case To Motherboard wired, the switch on the Case won,t kick the board Up.
    Mike @ compurepair.
    Hi Alan,
    I,d connect everything from the front-panel reset/spkrs et,c.
    Some boards run circuitry tests to see all is present.
    Also you,ll have an audible warning with the system spkr.
    Regards Mike.
    P.s thankyou for the Rating.
  • 298 Answers
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
07 ram. Clarion vz401 has blinking red light, thats it! Disconnected everything and checked fuses. Everything is fine. Will not power on no matter what i do
Hi Deli:
My suggestions:
- Use a voltmeter to confirm power supply
- Make sure power supply connected to correct wire.
- Confirm that unit is properly grounded. If ground wire, use continuity meter to confirm that ground wire is indeed grounded.
- make sure speakers are properly connected.
And last, but most important, Did the unit work before you tried to install it. There's not much fun in trying to make a dead unit entertain you.
Hope this helps.
Sep 08, 2015 | Computers & Internet
Common faults
If power supplier is working, check the start button. Make sure that all the wires are conected in the motherboard and there is no loose wires.
Oct 26, 2013 | Computers & Internet
My system is power on but it will not display anything on monitor
you can troubleshoot this problem very easily
  • confirm you connected all your cables including to monitor and 4pin power for graphics to MB
  • confirm your RAM is good, if you have two RAM, use single RAM for checking, replace with new
  • Clear BIOS by reconnecting Bios Jumper, if your jumper has 3 pins remove Jumper and connect with other two pins
  • If you have graphics card, check it, if you have doubt about this, use motherboard graphics, or replace with a working one,
  • if still not working after replacing new RAM and Graphics card, replace your processor, it will surely work if your motherboard has no problem
Thank you
Please rate me if is succeeded..
Sep 03, 2011 | Intel DG31PR Motherboard
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
Hi, i have intel d945gccr motherboard.few days ago when i push power buttom to on my pc then i see no any response from that buttom i open cabinet and see that everything is ok but processor fan not...
no motherboard is not dead..
problem is with your power supply.....
repair your power supply or connect new one best is connect new one because repaired will do problem after sometime ....
Dec 27, 2010 | Intel D945GCCR Motherboard
My laptop has a problem of not start once i switched on the on button
Hello Sir, Hi, if your laptop fails on power on, here are possible culprit.
  • definitely there is a power supply problem, these power supply modules are not really serviceable, you need to find a replacement, but if you cant find one, bring the power supply module to a reputable electronics service center, a TV tech. shop will do.
  • there is a possibility of battery problems, but you should see some LED lights on your laptop, to confirm battery is bad, have it replaced, or swap out a new battery,
  • there is a slim chance its the power switch, usually they don't response, if this is the case, replacement is needed, but this goes with the motherboard.
  • if everything else does not solve the problem, its the motherboard. if this is the case, there is not much more else to do, but replace the whole laptop, and but a new one, your dealer may help to contact the supplier if buy any chance may repair the laptop.
Jul 27, 2010 | Computers & Internet
My client has a p4m900-m4 mobo that was installed Oct. 2009. The system has 2 dvd players. He tried to play a dvd and the system shut off and now appears dead. I get a power light, one of the dvd players...
Hi
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or HDD or whatever as long as it's a drive) the CPU, graphics card (if required) and one bank of memory, unless the board requires dual matching chips.. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drives, make sure you set your pin settings for master/slave/CS are set correctly on it. Now, you should get the power supply on, and the cpu fan spinning. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or finally the motherboard. The next step is to replace each one of the elements with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that. I usally start with the drive, then move to the memory chip, next CPU, Last PSU. I also make sure that my replacements work on another machine first. If no change, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Please don't forget to leave a rating.
Thanks Mark
May 15, 2010 | Biostar P4M900-M4 Motherboard
I have an ACER AM5640 and it does not start. I replaced the power supply but still dead. No PST, no lights on keyboard. Nothing.
hi im rain ok it sounds like you may have a dead motherboard. acers are proned to motherboard failure. if the fan nore the led lights in front of your unit
are not working then you most likely have a dead motherboard. make sure all connections are correctly
seated. if so then your motherboard is most likely the problem. also check the power cord to insure that the cord is not the problem. further more try disconnecting the main power source to the motherboard wait 5 minutes to insure there is no ecsess power left in Motherboard. reconnect the main power connector back to motherboard and try booting up. if this fails then *********** board is the problem.
Nov 14, 2009 | Computers & Internet
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
May 06, 2009 | Microsoft Compaq Presario C501nr Notebook
No power
if you have changed and confirmed the psu and after that no power, then do a final test.
by the way, have u plug the power switch,reset switch, hdd led connector, power on led connector in the right pins on the motherboad. confirm it with the help of user manual , also mentioned in the motherboard too.
if all are in the right positions, and system still not working then do a final test.
remove all the power, data cables for all devices like cdrom,hdd,dvd etc. just plug the power plug of psu inside the motherboard and check. remove the ram too. the supply fan and processor fan should run without ram. but it should give a continuous on and off beeps.
if after removing all this, its still not working then it is surely dead.
Jul 24, 2008 | NEC /Packard Bell 4 DIMM AT Motherboard...
Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard Logo
170 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
