Question about Dishwashers
Dishwasher powder/tablet not being used
My dishwasher is not using the dishwashing powder/tablet to washer the dishes. it just dumps the powder/tablet out of the dipenser.
  • Anonymous Aug 07, 2008
    The dispenser opens during the cycle but it looks like it just ran down the inside of the door. The dishes do however seem clean, but we always rinse before loading the washer.
    Problem Solver:
  • 6 Answers
Yes
The problem is not enough water presure is hitting the soap dispenser. Probably the top rack of dishes is not getting clean either! look for my post about fixing with CLR and use that see what happens then
Thanks
Kashif.A
Posted on Mar 07, 2008
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
Soap powder in d.washer by mistake berko model no de 2541 will this harm the d.washer
Likely not dishwasher tablets / powder are generally harsher than soap powder. It would not be a good practice to do constantly as detergents are formulated for specific purposes they vary in pH, surfactants and other agents that keep dirt in suspension so it can be rinsed away. The dishwasher cleaners really should be used periodically as every now and then it is good to run a wash the machine rather then it washing dishes.
Feb 22, 2013 | Dishwashers
Dishwasher powder
Check inlet water quality. It's hardness level. Use salt meant for dish washers. There will be a salt fill compartment. Refer user guide.
Finally check whether the rinse aid dispenser has liquid for dispensing.
May 26, 2010 | Dishwashers
Dishes not coming clean
Five common causes:-
1. The dishwasher hasn't got any salt in, or the salt dispenser control is set too low. Even if your tablets/powder have a salt function, it's often not enough in hard water areas and supplementary salt must be added to the salt dispenser.
2. There is no rinse aid in the machine or the dispenser control is set too low. Supplementary rinse aid may be needed even with tablets/powder which claim to include it.
3. The dishwasher is not reaching the correct operating temperature. This can be due to a faulty machine, or by using low temperature washes inappropriately. Low temperature washes are only suited to very lightly soiled loads which have not baked/dried on. There ARE special low temperature tablets/powders, but they're designed only for specialised domestic machines with low temperature overnight wash cycles or for commercial dishwashers.
4. The filters/debris traps at the bottom of the machine are not clean.
5. You're using the "wrong" brand tablets/powder. In this instance "wrong" simply means that your machine just doesn't get on with the brand you're currently using. price has little to do with it; I find with my current machine that the market leading expensive brand works poorly but the ultra-cheap supermarket basic value brand works perfectly. Also it can be down to using a genuinely wrong tablet/powder choice as per suggestion #3.
May 15, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
ITS NOT REALLY CLEANING
I cannot tell you why your tablet doesn't clean well not knowing your machine, but having tried several types and brands (liquid, tablet, powder) I have found that the powder cleans best in my machine. Maybe it is something to do with dissolving or your water is not hot enough --possibly tablets work best in certain machines and not others. I don't have any interests behind my advice, but Cascade Complete was the one recommended to me and has become what I use exclusively. But I am willing to try others as technology develops.
May 12, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Fischer and paykell dish washer tablet doesnt melt
if that is a drawer dishwasher ck manual i believe it it says powder only the fp drawer dishwasher doesn't use much water so desn't have a lot of spray force to dissolve tablets
Dec 13, 2008 | Washing Machines
Soap left in the dish
With the LG LDS5811 dishwasher and other water/energy saving dishwashers, they are VERY ineffective with untra cheap powder detergent. Switching to Electrosol or Cascade has solved the problem -- and don't use too much.
If you add a whole house water softener, you will be AMAZED how much better your dishwasher and clothes washer work -- especially if your cut down on the amount of detergent your use.
Oh, never use gel or tablets in your diswasher. Ever.
if the problem with the detergent dispenser not opening is a seperate problem. Recommend you submit a seperate problem/question.
Good Luck!
Aug 26, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
My low detergent light is on while my wife uses tablets when she runs the dishwasher. I tried turning the power off to reset but it still stays on.
The low detergent light comes on because the dishwasher recognizes the powder or liquid wash detergent.
In the Tablet form the dishwasher things you do not have enough becasue the tablets are condensed tightly. I use the tablets and I ignore the low detergent light entirely. The tablet is good for ONE wash and is sufficient.
If your dishes are not coming clean, I recommend that you prewash or scrape dishes ahead of time.
May 24, 2008 | GE Dishwashers
Dish Washer
If you live in a hard water area the 5 in 1 tablets will only work half way. Consider Calgon powder or the tablets which can be left in the dishwasher cutlery basket as an additional measure. Hard water areas are notorious for leaving chalky residue on cutlery regardless of 3 in 1/5 in 1 tablet promises.
Also your dishwasher will require rinse aid too as most machines need this to mix in with the general water and soap solutions when the dishwasher is on its final rinse.
Apr 19, 2008 | Zanussi 24 in. DE6744 Free-Standing...
Dishwashers Logo
553 people viewed this question
Top Dishwashers Experts
