Cannot reset hours on clock setting - Televison & Video
  • 5 more comments
  • ki55 Mar 20, 2008
    I bought my 2nd DMR-E86H off ebay. I live in Wisconsin, and the DMR-E85H that I bought from ebay came from Ohio. So the time is off. I want to change the time (clock) manually, but it isn't highlighted, therefore I cant access the clock settings to change the time.
    I set everything to match my other DMR-E85H that I bought from a Best Buy locally, and still can't get into setting the clock manually.
    Can you help me?
  • Lee P Mar 29, 2008
    I lost my remote and users guide. How do I reset the time...with the change in daylight savings time?
  • Anonymous Jun 28, 2008
    Power went out...need to reset clock.
  • Jim Halpin Sep 24, 2008
    I can bring up the menu, but there is no option to set the clock.
    Zenith DVD+VCR / Model XBV443.
    The PDF manual shows ckicking on Menu brings it up, but all I get is DVD setup options ...
    Yes, can bring up the menu, but there is no option to set the clock.
  • lboyd3 Dec 31, 2008
    lost manual-how do I set clock for under the counter gpx cd/radio player?
  • Gene Wells May 11, 2010
    Make and model number please...
    Geno
    Master:
  • 518 Answers
Closed?
Posted on Mar 10, 2008
How to set the clock on a MT01
To set the clock
1. Turn the key to "ON".
2. Push the "SELECT" button and
"RESET" button together for at
least two seconds.
3. When the hour digits start flashing,
push the "RESET" button to set the
hours.
4. Push the "SELECT" button, and
the minute digits will start flashing.
5. Push the "RESET" button to set
the minutes.
6. Push the "SELECT" button and
then release it to start the clock.
Oct 22, 2013 | Yamaha MT-01 Motorcycles
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
Adjust the time clock on the 2005 xt660x please
G'Day Dutchgbg
Here is a quick guide to set the clock
1: Push the "select" button and the "reset" button together for at least two secounds.
2: When the hour digits start flashing, push the "reset" button to set the hours
3:Push the "select" button to fix the hours, and the minute digits will start flashing.
4: Push the "reset" button to set the minutes
5: Push the "select" button to fix the minutes, and then release it to start the clock.
regards robotek
Apr 09, 2010 | 2005 Yamaha XT 660 X
I have the georg jenson wave clock but don't know how to toggle between the 24/12 hour clock. Right now it's set for the 24 hour clock and I live in the U.S. and want the 12 hour clock setting.
Well...this solution may be a few years late for the original poster, but I did figure it out on mine. If it's the same clock that sits on a rubber stand and you press the top edge back to activate the light, to toggle between 12 hour and 24 hour clock, you press the + and - buttons, simultaneously, for 3 seconds.
Jan 19, 2010 | Jensen Audio Players & Recorders
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
How do u reset the time on a honda civic 2004
Press and hold the CLOCK button until you hear a beep. Change the hours by pressing the H (Preset 4) button until the numbers advance to the desired time. Change the minutes by press the M (Preset 5) button until the numbers advance to the desired time. When you are finished, press the CLOCK button.
Vehicles without CD Player
Adjust the hours by pressing and holding the CLOCK button, then pressing the H (Preset 4) button. Adjust the minutes by pressing and holding the CLOCK button, then pressing the M (Preset 5) button
You can quickly set the time to the nearest hour. If the displayed time is before the half hour, press and hold the CLOCK button until you hear a beep, then press the R (Preset 6) button to set the clock back to the previous hour. If the displayed time is after the half hour, the clock sets forward to the beginning of the next hour.
For example: 1:06 will reset to 1:00 or 1:52 will reset to 2:00
Hope this gets you there.
Oct 30, 2009 | Honda Civic Cars & Trucks
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Sep 30, 2008 | TruTech Clock Radio
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Televison & Video Logo
639 people viewed this question
Top Televison & Video Experts
