Question about Dishwashers
Kenmore automatic dishwasher
I have a 7 (?) year old dishwasher. It has done good work for a long time. Lately tho, it has started to emit a whining at the end of the pre-wash cycle. The old water seems to drain out but the fresh water does not come in. Thats when the whining starts. Last time I was able to get it going again by manually moving the dial ahead one notch.
Now today we ran the dishwasher and no problem. So the problem is intermittant, but i'll bet it gets progressively worse. Is it a timer problem??
Any ideas?
Thanks, Mike
  • Mego1945 Mar 09, 2008
    Thank You Kashifz,
    I'll try that tip on the solenoid. Does anyone know where's a good diagram online for a Kenmore dishwasher?
    Thanks,
    Mike.
    Problem Solver:
  • 6 Answers
Sounds like a Bad Solenoid. Locate the part then tap it with the back of the Screw Driver during the cycle. see what happens.
good luck
Kashif.A
Posted on Mar 07, 2008
DISHWASHER LEAKING FROM CENTER OF BOTTOM OF DOOR
It's possible the bottom spray arm isn't rotating, and all thenwarermis being sprayed directly at the center of your door. Check this first. end, check the spray arm isn't damaged, as this can alter the spray pattern.
Jan 12, 2018 | Kenmore Dishwashers
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
How can I chech the heating element to see if it's working?
Good Afternoon Friend,
I understand you have a 7 year old Kenmore dishwasher, which you want to know how to check the heating element to see if it's working. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine if the heating element is working. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire 24 in. FDB510LC Free-standing...
I just bought a good used 4 year old dishwasher
check to see if the fill hose or inlet hose is kinked , or u need a new water valve or flow meter
Oct 27, 2009 | Kenmore Dishwashers
Kenmore Dishwasher Holding Water
lost your tube that supplies water to upper spin rack? look in your strainer
Apr 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have Kenmore dishwasher type 575-0 it is leaking
did you pull the bottom cover off and watch it run it could be either thesupply line developed a leak or the drain tube has done the same or in most cases with dishwashers relatively old the pump has cracked in which case the washer is trash
Apr 07, 2009 | Dishwashers
Kenmore quiet pak III dishwasher has a whining noise
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z --- www.repairclinic.com
http://www.repairclinic.com/Kenmore-Dishwasher-Parts
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Soap door won't open
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
375 people viewed this question
Top Dishwashers Experts
