Question about Vacuums
Miele Service Manual
Does anyone know where I can buy or get a copy of a Miele Capricorn S5980 Canister Service Manual? I am also looking for a service manual for the Miele Power Plus SEB236 power nozzle as well.
Where can I get a copy of a Miele S 230 i cannister vacuum service manual and model # of the right dustbag. Thank you.
Posted on Sep 25, 2008
My Miele S 558 hose keeps powering down while vacuuming. I understand that the newer SES 125-3 hoses are supposed to correct the problem. Before I buy, I'm wondering if this has proven to be true.
Debra, Searched the net. and the problem does seam to be poor/faulty circuit board in the hose and the SES 125-3 replacement hose is to be the fix. You could dissassemble first and clean the contacts first, to see if you can correct and extend the life of old hose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
just bought Miele s558 Silver Moon seems like it from 2000 or so If it in...
My Miele S5980 is cutting out How do repair the hose to fix it
Amazon com Miele SES125 Vacuum Cleaner Deluxe Electric Hose Miele Vaccum...
Jul 08, 2016 | Miele Vacuums
My miele capricorn vacumn will not turn on
I admittedly know absolutely nothing about that brand EXCEPT that they all have an automatic shutdown feature if they get too hot. Accordingly, there must be a reset button somewhere, and the manual will tell you where it is. Either that or they simply won't start again until they have sufficiently cooled down. Beyond that, I have no idea.
May 23, 2016 | Miele Vacuums
The red filter light will not reset after replacing the filter on my Miele S5980
Hi There, I actually did a repair on this problem only a couple of weeks ago. The problem could be that the small lever that pushes on the reset button on the circuit board is bent or broken. The little button costs about $10 from memory and certainly a whole lot cheaper than the board itself which is $234. Just to clarify in my case there was nothing wrong with the board, I was able to manually push the reset switch on the board and replace the tiny lever and problem was solved.
Apr 17, 2013 | Miele S5980 Capricorn /SEB 217
Miele vacuum s5980 no power
your main circuit board is also your speed control the motor should not have a circuit board i don't believe. open your machine up all the way to the motor and cord reel. check voltage at cord reel should be 120 +/- 10. if voltage is correct then replace speed control board.
Feb 12, 2013 | Miele S 5980 + SEB 217 Bagged Canister...
My Miele Vacuum s5980 power cuts in and out?
Go to support on the Miele website. Enter your model number and search trouble shooting for your solution.
murf427
Aug 02, 2012 | Miele S 5980 + SEB 217 Bagged Canister...
No manual...
Here's a link to the USA version of the Miele S4210 Canister vacuum. You may visit this link and download the .pdf file, or just print it out if you'd like to have a paper copy.
http://www.mieleusa.com/manuals_pdf/Residential/Vacuums/S4000_us.pdf
I hope that this helps you with your new vacuum!
Chris J.
GoVacuum
Mar 30, 2010 | Miele S 4210 Bagged Canister Vacuum
Buying spares Meile 250i
Hello Dave,
You'll want to contact Miele directly and they can direct you to your nearest shop
Miele Dealer Locator (vacuums)
(888) 785-2828
Monday-Sunday: 24 hours
Sep 05, 2009 | Miele S251i Plus Bagged Canister Vacuum
Vacuums Logo
2,106 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
