Question about Fuji FinePix S5500 Digital Camera
How do you change the shutter speed on the finepix s5500?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Posted on Mar 09, 2010
SOURCE:
Changing shutter speed
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Mar 03, 2013 | FUJIFILM FinePix JZ300 Digital Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
I have s5500 fuji film please tell me whats sitting speed and oprercher with a vrey hot day full sunshine
It's impossible to tell you what shutter and aperture settings would be best without actually being there. Why don't you just rely on the built-in meter? On a bright sunny day, you could set the ISO to its lowest setting and let the camera figure out the correct exposure.
Mar 10, 2010 | Fuji FinePix S5500 Digital Camera
How do you change the shutter speed on the fuji s700?
You can't manually change the shutter speed. It does change on its own when you change modes. If you want more control over shutter speed and aperture, you need to step up to a DSLR camera.
Jan 08, 2010 | Fuji FinePix S700 Digital Camera
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
Apr 10, 2009 | Fuji FinePix S7000 Digital Camera
Changing Shutter Speeds
The +/- button is located on the bottom right corner on the back of the cam. If you do not find it on your cam, probably "you are not using a Genuine Fuji S5700".
Aug 07, 2008 | Fuji FinePix S5700 Digital Camera
Shutter problem...
Kindly explain the problem in detail. i.e.
1) how did this happened. all of a sudden or you dropped the camera, or something else.
2)when you half press the shutter button, does the camera focus , or its keep on trying to focus. if the camera would not focus the image it wont take the picture.
3) even it focuses the image instantly and still it is taking long time to expose the photo. ???
Mar 14, 2008 | Fuji FinePix S5500 Digital Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
Fuji FinePix S5500 Digital Camera Logo
464 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
