Question about Acer Aspire T135 PC Desktop
"this copy of windows must be activated..."
We couldn't find the startup disks a while back so we used another computers startup disk. This is for my daughters computer, so I did not find out until it was too late. I do not have a product key as the sticker is torn off from moving so much but we have found the original startup disks that came with the computer. I've been trying to do a clean reinstall, but this other computer system won't let me get past the dreaded "this copy of windows must be activated... window". I've called acer once, and she explained to just tap ESC on startup and boot from the CD/DVD. This did not work. Any suggestions. Thanks
  • eujil1 Mar 07, 2008
    'Ive called acer once, and she explained to just tap ESC on startup and boot from the CD/DVD. This did not work.
    By tapping ESC, I did go to the BIOS setup and changed the first boot drive to CD/DVD and f10, and restarted windows normally. Same problem. I'm curious that you said "press any key to boot from cdrom". I might add that during the restart I did not press any key. Thanks for your reply
If you're trying to bypass expires windows xp installation and you don't want to format it just to access then follow the link to help you for free. kasikas forum
Posted on Sep 17, 2008
If you want to learn how to bypass expires windows xp installation then follow and post your problem on the link provided: http://kasikas.com/forums/viewforum.php?f=211
    Genius:
  • 1,226 Answers
Hello!
Im affraid to answer this question because im sure that you rate me 'thanks for trying" but its ok as long as i can help.
well, In most cases, that problem will be resolve by directly going to the insternet and activate.
this statement is also correct" boot from the CD/DVD." Are you sure that the cd/DVD is ok. ? If the original CD is a bootable disc then you have no problems . You should reinstall using the original CD.
1. at frist boot, press'F2" of "Delete" to enter the bios setup.
2. find the first boot setting and change it with CD rom and then pres "F10" to save and exit the setting.
the sytem will restart automatically. then press any key to boot from cd rom.
You are done.
please tell me the problems if this solution won't apply i will give you further solution.
best regards, melnavz
Posted on Mar 07, 2008
  • Emelio Navaja
    Emelio Navaja Mar 07, 2008
    thats right . when the computer prompted you to press any key to boot from cd rom you should press that so that the windows boot from a bootable disk (the original disk) and continue setup a newly fresh windows onto the system.
Cant remember my original password
If its for a windows pc...you may want to consider a password reset disk if you have one...or if you set a hint...use it to try to remember. If all else fails you might want to reinstall windows using a reinstallation disk which you can boot from startup. Once booted...you can choose to install a new copy of windows. Follow the install procedure...install to a disk with reasonable space and wait for it to complete. Then proceed to download and utilize a windows activator..which removes the windows license activation process.
Dec 16, 2014 | Computers & Internet
Tip
A boot disk (startup disk) and why you need it?
The Windows installation disc contains the files necessary to start Windows, so it is itself a boot disk. A boot disk is actually not a computer disk in the shape of a boot. If it was, most disk drives would have a difficult time reading it. Instead, a boot disk is a disk that a computer can start up or "boot" from. If a problem is preventing Windows from starting, you can use the installation CD to start Windows. The installation CD also contains Startup Repair, which you can use to repair Windows if a problem prevents it from starting correctly. Startup Repair can automatically fix many of the problems that in the past required a boot disk to fix.
A boot disk (sometimes called a startup disk) is a type of removable media, such as a floppy disk or a CD, that contains startup files that your computer can use to start Windows. CD and DVD boot disks are often used to start up a computer when the operating system on the internal hard drive won't load.The startup files are also stored on your computer's hard disk, but if those startup files become damaged, you can use the files on a boot disk to start Windows
Earlier operating systems that used the FAT or FAT32 file systems, such as Windows 95 and Windows 98, a boot disk was especially useful because it allowed a person to access files on a hard disk even if Windows was unable to start. This ability also represented a security risk, because anyone with a boot disk and access to the computer could start the computer and access any file. Hard disks formatted with NTFS have built-in security features that prevent using a boot disk to access files..
Let looks at some useful "boot CD downloads" to create one for Windows OS,s.
1-Ultimate Boot CD for Windows - This BartPE-based boot disc comes with a huge selection of tools to access your data and get your PC booting properly again. Some of them are even useful.UBCD takes a long time to load and asks you some odd questions before it's finally up. But once it's there, you can edit the Windows Registry (yes, the one on the hard drive) in RegEdit, recover deleted files, and even run benchmarks. setting up UBCD is identical to creating a BartPE disc--with the same possibility of failure. But when it works, you get a lot more.Price: Free
Download Ultimate Boot CD for Windows.
2-Puppy Linux - A third party application to create a boot CD using Linux and great for accessing NTFS-formatted hard drives--especially if you're not comfortable with Linux's whole mount concept. Just open the Drives window and select a drive, and Puppy will mount it for you--in read/write mode, if possible.Puppy will mounting the drive with read/write permissions and you not only can copy your files elsewhere, but you can also edit them. Puppy Linux comes with AbiWord, which supports .doc files, and Gnumeric, which supports .xls. And even if it mounts read-only, you can still copy the files to an external drive, most of which are formatted in the universally accessible FAT32 file system.
But be careful how you click. Actions that take double-clicks in Windows, such as opening a file, take only one in Puppy.
Price: Free
Download Puppy Linux.
3-BartPE - The BartPE operating system makes a pretty good boot disc on its own, getting you into Windows and letting you access your drive. It doesn't have much in the way of repair utilities, but it has chkdsk, which should probably be the first one you try.To create a CD, the program needs the Windows 2000 or XP installation files. One place you're sure to find them is an actual Windows installation CD-ROM. But the recovery disc that came with your PC probably doesn't have them.
Luckily, if your PC came with XP installed (and thus, not with a true XP CD), the necessary files are probably in a folder called C:\Windows\i386. But I do mean probably, not definitely. However, since the PE Builder is free, you're not losing much if it can't create a disc.
Price: Free
Download BartPE.
4-Vista Recovery Disc - a unique distribution of Microsoft's own recovery tools.This Recovery Disc is basically a Vista installation disc minus the install files. It even has an "Install now" button that asks for a Product Key before failing. You're better off clicking the Repair your computer button. Among its Vista-only options are a tool for diagnosing and fixing startup problems, a version of System Restore that uses restore points on the hard drive, the restore portions of Vista's backup program, and a memory diagnostic tool. Price: Free
Download Vista Recovery Disc.
5-Trinity Rescue Kit - TRK's command line interface could humble anyone but the most devoted Linux geek.
If you take the time to read the 46-page documentation and learn the program, you'll be rewarded next time disaster strikes. Among the tools that will be at your disposal are a script that runs 4 different malware scanners, a tool for resetting passwords, a Registry editor, a program that clones an NTFS partition to another PC over a network, a mass undeleter that tries to recover every deleted file on the drive, several tools for recovering data off a formatted or dying disk, two tools for fixing master boot record repair programs, and hardware diagnostics.
Price: Free
Download Trinity Rescue Kit.
Hope that you understand the benefits of having a boot disk on your wardrobe.
on Jan 04, 2011 | Computers & Internet
Tip
Windows startup does not complete.
Hi.
If The BIOS is showing initial splash screen, and completing POST test correctly, but Windows Startup does not complete, and you are in one of the following situations:
  • You get a black screen with a cursor blinking.
  • You get a black screen with test or command prompt.
  • You have a blue screen with a warning message.
  • Windows keep restarting.
  • Windows is freezing.
Any of the condition described must occur before getting to login screen or to Windows desktop, or the problem is other than the one described here.
If you get a message saying Operative system not found you may also be in same situation. Only in that case the disk may also be physically damaged, and you may have lost your data, or disk may need replacement.
The conditions above usually tell us that the Windows system files needed for Startup are corrupted.
Windows cannot load the files anymore and will hang on with the cursor blinking.
When this happens you need to reinstall the operative system.
To start you can try loading the system in safe mode, by pressing F8 on Startup.
If the computer is starting in safe mode, try doing a system restore to a recent date before the problem started. This will be faster than installing a fresh system, and most of your settings will be preserved.
You may find out that when the system does not load, most computer will not even start in safe mode.
Check also that there is no CD, DVD or floppy inside the computer, also disconnect any connected USB device, apart mouse and keyboard, and attempt starting the computer again.
If all that does not work, then you will need to reinstall Windows.
Installing Windows is not a complicate operation, all you need is the computer recovery disk, or a Windows install disk valid for the licence number printed on the Microsoft Certificate of Authenticity sticker.
If you use a recovery disk, remember to choose partial recovery, so that the original data contained in the hard disk won't be deleted.
Using Windows generic disk you will need to choose Update Recovery if asked, install the system on top of the same directory (eg: C:Windows), and you will also need to choose Leave System File Intact, when asked by Windows setup.
Using a Windows generic disk you may also need to install additional drivers, that usually are available for download from the manufacturer website.
Even choosing a partial recovery , or an update install, some of the installed software may be affected, and may need a fresh setup.
Another way to proceed is installing a copy of windows into a different folder (eg. C:/Windows000), and choosing to leave system file untouched.
This will reinstall system files hosted in root folder, and sometimes may bring back to life the old system.
In that case you will be asked what system to start from Windows boot manager on Startup, your old system will be the second one.
Using this method is better to remove the new installation Startup from boot manager after installing and testing that the old system is back at work. This is done editing the system hidden file Startup.Ini, hosted in root folder. The file is a text file.
If you have important data inside the hard disk, it is always advisable to copy all data onto an external media. Even if the procedures described normally do not delete your data, when doing maintenance on a computer there is always the chance to loose data.
If the computer is not starting because of a system problem, the data can only be recovered using a boot disk, or physically removing the hard disk drive from computer, and connecting it to a different computer (an external enclosure may help).
This same instructions broadly apply to all recent Windows operative system, Windows seven setup is slightly different from the procedure described here.
on Dec 11, 2009 | Microsoft Windows Vista Home Premium with...
I need to repair vista operating system
Step 1:
The first thig to do is locate the serial key if its not located on your computer you can find in the registry. http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
Download the Windows Vista startup disk .ISO file. A .ISO file is a "disk image" file, meaning that it is a compressed archive of all the files that would normally be found on a CD contained in one simple file. Microsoft does not provide users with an official Windows Vista startup disk. Because of this, a number of services online provide their own for users free of charge. Download the .ISO (see Below) file to your computer's desktop. http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/ Put a blank DVD in your computer's DVD writer. Open your DVD burning program. As long as your program can burn .ISO files, you can use any software you'd like. Burn the .ISO file to a DVD by selecting the "File" menu, clicking on "Open" and locating the .ISO file from your hard drive. Next, click the "Burn" button in your DVD burning software and the files contained in the .ISO will be burned to the disk. Label your Windows Vista startup disk with a pen or marker and keep it in a place where you won't lose it. If your computer is damaged to the point where you would need a startup disk, you won't be able to use your computer to make one. It is very important that you do not lose this disk.
Mar 05, 2013 | Systemax Venture H356 Desktop Computer -...
Upgraded motherboard and windows 7 in restore during startup
If you put in a hard drive that already had an OS on it and such, it won't work since the new computer has different parts from the last. You will have to buy Windows 7, or obtain windows through some method of your choice and do a clean install. Sorry buddy.
Feb 21, 2013 | MSI B75A-G43 Motherboard
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
Hi everyone, I would just like to know, does anyone know how I can obtain or create an emergency boot up disk for windows xp home edition? Many thanks. Andrew
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
Jan 15, 2010 | Computers & Internet
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do I re-format a 2x serial SATA drive to reinstall XP?
How to Format a Hard Disk
After you create the partitions, you must format the partitions:
Restart your computer with the Startup disk in the floppy disk drive.
NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
Extract ebd.cab format.com
After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
3. When you successfully run the Format.com tool, you receive the following message:
WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format?
4. Press Y, and then press ENTER to format drive C.
5. After the format procedure is finished, you receive the following message:
Volume label (11 characters, ENTER for none)?
NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
Jul 25, 2008 | Computers & Internet
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Acer Aspire T135 PC Desktop Logo
6,715 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
