Oki C8600 control panel detached when delivered...
I've just bourght an oki C8600 but the control panel was loose in the box when delivered.
Is there an easy way to reconnect it, or should I be seeking pro help?
Many thanks.
  • Andy Baptiste
    Andy Baptiste Mar 07, 2008
    Yeah, could be mate, its just that the whole thing looks like its made to 'fall apart if you look at it' I thought it might be a trivial job to put it back together.
    Actually I have reconnected it now, but the display is just blank.
    In the ebay listing I got it from it said 'still under warranty' but no paperwork came with it, so I'll chase that up...
    Thanks for the advice IB4G2008.
    Andy
    Genius:
  • 3,587 Answers
Nope..i'd send or take it back, myself..could be a loose ribbon cable underneath, too, eh?
Posted on Mar 07, 2008
Z32 back fire and smoke after hitting pothole
Hello Zack...
Sounds like the shock delivered by the pothole has caused a connector or some other electrical lead to detach itself..or if it was it wet and or raining when this problem first occurred has introduced some water where it should not be.
Start by carefully inspecting the engine compartment for loose wires, connectors or for anything that looks amiss. Check for secure grounding points and (if it was wet and raining) any water that may have pooled in locations it would normally not reach.
Check you air filter and filter box for moisture and let us know how your making out.
Aug 16, 2017 | Cars & Trucks
HOW DO I FIX EPSON C8600 E520 ERROR?
This site:
Thread Epson Aculaser C8600 Service Req E520
says, "If you're not a technician, I'd suggest doing what the error says and calling a qualified service organization."
Feb 26, 2015 | Epson Stylus C86 InkJet Printer
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Epson aculaser c8600 error message E833
my codebook said that in this particular printer service request e833 point to mis-assy ...
i do not know where are you located but in germany this bit cost over 300euro... bit can be exchanged on site by yourself, it is front part of the side feeder assy...
if you find my answer helpful, please do not hesitate to vote4 for me, thanx!
Aug 01, 2010 | Epson AcuLaser C8600 Printer
How do I get to the control panel on a Maytag washer?
First, does the machine stop filling if you pull the plug? If not, he is wrong and you need the fill valve. The piece the hoses go into. If it does stop when plug pulled then he is likely correct.
Pull machine away from the wall. Disconnect power. The control panel has two plastic end caps. The rear edge of each end cap will show a hole which has a partially covered Phillips head screw in it. Put a screwdriver in and remove the screw in each end cap.
Move to the front of the washer. Grasp each end cap and pull straight toward you about 1/4 " to 1/2 " then lift. The control panel should disengage from the top of the machine. The top of the control panel stays attached to the back plate of the washer. Rotate the front of the control up. This will expose all parts in the control panel.
Look for a 1/4" clear hose coming from inside the machine to one of the switches. This small hose can become detached from the switch and not send the "full" signal to shut the water off. It may also develop a small air leak which prevents the signal. If the hose is detached...reattaching and adding a hose clamp will prevent future detachment. if not detached, the pressure (level) switch itself is likely the problem.
Reverse the above process to reattach the control panel. If the machine is full spin to empty before testing your repair to remove water from tube. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
OKI C8600 service manual.
http://safemanuals.com/user-guide-instructions-owner-manual/OKI/C8600N-_M
I don't know if it is this but i hope it helps
Cheers
Jun 21, 2009 | Oki Electric Industry C8600n Led Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
K image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
Mar 31, 2009 | OKI B4600 Printer
Oki c9600 printer - waste toner box
Sometime the white round spring action mechanism on the printer breaks which causes the toner box warning This mechanism connect to the printer toner box when installed.
Feb 20, 2009 | OKI C9600hdn Laser Printer
OKI C8600 Printer Toner Sensor Reset
I've had two toners that have done this, they register as used as soon as you turn the dial to open the toner compartment. So if they don't work properly, as soon as you remove them.. you can no longer use them. (they empty contents into the drum).
I got in contact with my supplier and sent them back as faulty cartridges.
Sep 30, 2008 | Office Equipment & Supplies
214 people viewed this question
jasbo
jasbo
