Cars & Trucks Logo
Posted on Mar 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an 85 chevy 4x4. I just had the 305 engine rebuilt with a new intake and carb. It was working fine for a couple days and one morning I went to start er up and the engine just cranked and cranked, wouldnt turn over. So I left it there for a day, went back the next day and tried it,and it started right up. Worked good for a a day, then the next day I went to start it up and same thing, it just cranked but wouldnt fire up.....so I left it there for the majority of the day, went back, and tried to start it and it started right up......can you think of why it's doing this? especially sense i had the engine rebuilt.
  • Anonymous May 11, 2010
    Basics 101. Spark? Fuel? Air? I'm guessing there is a fuel delivery problem. Intermittent.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Dec 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
2141
Points
8
Sounds like the electronic ignition. (the thing that replaced points in the early 70's)
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 146 Answers
  • Posted on Mar 08, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
146
Questions
0
Helped
47011
Points
363
When you turn the key front. Listen for the fuel pump to prime. It should sound like a low humming noise that lasts about 3 seconds. If it does then check for spark by pulling one of our sparkplug wires and putting an extra spark plug in it. Place the end of the wire down somewhere safe and crank the motor. If you can't seek spark in the plug, it is most likely your coil failing. So, check fuel pump and fuel pump relays first, then spark. Good Luck.
  • Anonymous Nov 19, 2010
    85 Chevy 305 has a carburator with a mechanical fuel pump, fuel issue is very unlikely with the conditions discribed and since a vapor lock is unlikely with the fuel return line present on the 85 models, this is most likely a electrical problem
1helpful
85 jeep cherokee 2.5l runs fine on level ground but the carb floods when I'm going up hills? Any solutions? Its been tuned up new plugs and wires and everything but why is it flooding?
Your carb is needing to be rebuilt the seals and float and valve seat may be damage. The float opens when the fuel level in the carb is low. If the valve seat is damaged or the float is not working. Gas can keep pouring into the carb resulting in extra fuel. Till the engine stops and fuel pump pressure stops pushing fuel it will keep pouring fuel and will not stop till rebuilt correcting the problems. Buy rebuild kit and rebuild it or try junkyard and replace it.
2answers
My 85 f250 460 engine with holly carb starts up then engine races way to high
In 85 Ford used a carb spacer that also had the EGR attached.
It could be that the gasket has broken and it has a large vacuum leak. Also the EGR could be stuck open. Look for other vacuum leaks like the PCV and brake booster vacuum systems. A 460 engine will run with huge vacuum leaks especially when the choke is on but the extra air will lean out the mixture and could cause damage.
Enclosed is a video about setting idle on a Holley carb which you may not need but others looking at this post may like to see.
I have a 454 chevy engine after it sits fir a couple of weeks or month when you try to start it it backfires. I have to prime the carb and it starts right away. Does the carb need rebuilt?
You might try to richen that carb intake a bit. You might want to spray some intake cleaner in the intake as well and make sure to get some of the gunk out of there. I would add a fuel system cleaner in the tank as well but a rebuild will net the best results.
2answers
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
2answers
Got a rebuilt carb for a 85 ranger 2.0 will not idle right
Check all vacuum hoses for cracks and disconnections. Also check pcv and egr
1helpful
1980 F100 with a straight 6 cyl. Won't idle.
The vacuum comes from the intake manifold and ported vacuum comes from the carb above the throttle plate. You might have a leak at the carb gasket or intake manifold gasket. Spray some car cleaner or WD40 around the gaskets and vacuum lines while the engine is running and when you hear the idle speed up, you've found the leak. You will need to install the rebuilt carb first, and you should tighten any loose intake manifold bolts. Don't overtighten them. Also check the EGR valve because it could cause the engine to stall at idle. A good tune up might be needed too. I've seen some of those engines run real rough when the ignition timing was off.
Truck won't start
If it has a vortech V8 It has to have the right fuel PSI or it won't start. Also pick up in distributor could be causeing problem. Cross over style distributor cap also can cause problem. Out of oil? Fuel pressure regulator where found inside the intake manifold with injector cluster, if fuel psi regulator goes bad could be leaking fuel in intake causing oil to get deluted and burn.
1helpful
85 ford f 150 hard to start when cold
well it could be that you need new spark plugs definatly new piston rings hmmmm was it hard to start before you put the new carb on?
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
