HI
My Compaq nx6320 laptop won't power up. It is plugged into AC power and power turned on. When I push the power on button, the little lightning bolt light at the front of the laptop flashes a few times then stops - then ...nothing.
Any ideas please?
Thanks, Dave
Check your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
Problem solved - AC adaptor faulty. Battery was dead due to not getting power from AC adaptor. Replaced adaptor and all good.
