Unplug the dryer and pull it away from the wall.
On the back of the dryer near the top you will see a metal cover, usually just above where the cord comes out.
Unscrew any screws in this cover, usually only 1 1/4 inch or 5/16 inch screw that may also have a phillips or common screw head.
Once this cover is removed observe the cord going to the back of your dryer. There will either be 3 wires connected to 3 posts or 3 wires connected to 3 posts and one wire connected to the cabinet.
Remove the wire connected to the cabinet first.
Next unscrew the 3 screws holding the plug onto the terminal. Depending on how the end of your cord is made you may be able to just loosen these and pull the cord down or have to remove them completely. Do not drop these in the dryer!
Now just replace the cord with the new one and refasten the screws. Make sure they are extremely tight where the cord connects to the terminal block.
If you have a 3 prong cord with 3 wires the middle wire must go to the middle terminal and the other 2 can go on either side.
If you have a 4 wire cord the white wire will go to the center terminal, the black wire will go on either the left or right post and the red wire will go on the left or right post. One wire per post!
The last green wire will attach directly to the back of the dryer, usually with a 5/16 screw. This is just your ground wire.
Hope this helps.
A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
