Question about Compaq Presario 5000 PC Desktop
Ide issues hard drive wont boot with cables connected but when i remove ide cable the hard drive kicks into life. have changed cable , replaced power supply and tried another hard drive but no change also reset cmos . no help. please help .
  • speed1 Mar 07, 2008
    cant access hard drive or cd rom with data cables attached . only goes when i remove cable.cant access bios either . wont do anything except cpu fan spins .
    Sergeant:
    Champion:
  • 277 Answers
Create partiion and format hard drive.
Posted on Mar 07, 2008
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Tip
How to replace a hard disk drive.
Step 1: Back up and scout around
First, back up your critical files (don't forget your Outlook .PST archive) to optical discs, an external drive, or online storage. Then check whether a CD comes with the drive, providing drive-specific information and general upgrade assistance. It may also later help you copy the contents of one drive to another. Install this software first. Then, power down your PC, unplug all cables, and open the case. Next, ground yourself by touching a metal portion of the chassis.
Look inside—your first task is to determine where your new drive will go. Bays for internal drives are usually located below the wider, front-accessible bays that house CD or DVD drives. If you plan to replace your boot drive with the new drive and don't have an empty bay, your upgrade will involve more steps than we can cover here. But if you're replacing your boot drive and you have an empty bay, follow our steps for adding a second drive. After formatting it, use Norton Ghost (or a similar program) to clone your boot drive's contents to the new drive. Then, revisit steps 3 and 4 to direct your PC to boot from the new drive.
We'll be installing a SATA drive, but the process is similar for the other common drive type, IDE. SATA drives use a thin, seven-pin data cable; IDE drives use a 40-pin ribbon cable that's usually gray. If you're unsure which drive type your PC already has, check its documentation or label. Most PCs more than a year or two old employ IDE hard and optical drives, and don't support SATA unless they have a SATA PCI card installed. More-recent desktops may use (or just support) SATA drives but should support IDE, too.
Tip: If you transfer Windows XP from one drive to another, you may have to reauthorize Windows. Step 2: Examine data and power connections
Most hard drive kits include a data cable (SATA or IDE, depending on the drive), a power adapter cable (with some SATA drives), and screws. If yours doesn't include cables, you can purchase them separately.
First, the data connection. If you're installing a SATA drive as secondary storage, follow the data cable from your current drive (assuming it's SATA, too) to the other end. See if an unused SATA port lies nearby on the motherboard or an interface card. If you can't find one, consult your PC's documentation.
If you're adding an IDE drive as a second drive, you may be able to connect it to the same data cable as your primary IDE drive, or along with an IDE optical drive. Look for a third, free connector in the middle of the cable that connects your currently installed IDE drive to the motherboard. Note that some older PCs use 40-conductor IDE cables, not the 80-conductor ones current drives require. (Compare your kit cable to the one installed—the 80-conductor variety has much thinner wires.) 80-conductor cables are backward-compatible (both types use the same 40-pin connector), so you can swap out a 40-conductor cable for your kit's 80 if need be. (The "master" drive goes at the end—see step 3.)
Next, consider the power connection. Our SATA drive has a 15-pin SATA power connector. If you already have a SATA drive installed, follow its power cable (the wider of the two connectors) to see if an unused power-supply lead with the same connector is nearby. If so, earmark that lead for your new drive. If it can't reach the empty bay, see if any bundled adapters help.
Some SATA drives also support familiar legacy Molex four-pin power connectors—you can use a Molex or SATA connector. If so, hunt for a free Molex-style lead. Still no match? Then you'll need an adapter, such as a Molex-to-SATA adapter (some kits bundle one), or a Y-adapter that splits a lead in two.
IDE drives are simpler: They always use Molex connectors. You just need a free Molex-style lead (or a Y-splitter). Step 3: Mount and connect the drive
When installing SATA drives, jumper settings usually aren't an issue. That's not true of IDE, where a jumper indicates whether a drive is a primary ("master") or secondary ("slave") drive. Check its documentation for the proper setting. If your PC has only one IDE hard drive, it's probably set to "master." Assuming you chain another IDE drive off its cable, the new drive should be set to "slave." (You'll later have to change the jumper to "master"—and attach the drive to the cable's end—if you remove the original boot drive and make the new drive the boot drive.) Another option: Set both IDE drives on an 80-conductor cable to the Cable Select (CSEL) jumper setting. The PC will determine master/slave status according to the drives' placement on the cable ("master" at the end, "slave" in the middle).
Next, look at your current hard drive to see if mounting rails are attached to its sides. If so, screw a set onto the new drive (look inside the case for spares), then slide the drive into its bay. Otherwise, screw it directly into the bay. Four screws are sufficient. Usually, the label side points up; mimic the boot drive.
Attach one end of the SATA data cable (which is keyed for correct insertion) to a SATA port on the motherboard or interface card, the other to the drive. IDE data cables, also keyed, usually have a red stripe that lines up with the "pin 1" marking on the drive.
Next, plug the power-supply lead (keyed, too) that you scouted out in step 2 into the drive, including any necessary extender or adapter. Then close the case. Step 4: Configure the BIOS
Next, boot into your PC's BIOS-setup utility to verify that it recognizes the new drive and positions it correctly in the drive hierarchy. (Check your PC's startup screen to determine which key launches the utility.) Once there, also check that "auto-detect" is selected for the drives, if an option. If the utility lets you select the boot order, give your intended boot drive priority over any other hard drive. This information may be under Boot Options, Boot Order, or Boot Sequence.
Save changes and exit the utility. Your PC will reboot.
Tip: Using a SATA PCI interface card? It may have its own BIOS to check. Step 5: Partition and format your hard drive
Our PC runs Windows XP, which lets you partition and format drives within Windows. Older Windows versions, such as 98 and Me, make you do this from DOS.
With XP and 2000, though, use Windows' Disk Management utility. Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard.
Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Formatting could take an hour or more, depending on drive capacity. But don't be surprised if your formatted drive has less capacity than the package claims. A 320GB drive, for instance, formats to about 300GB. Drive manufacturers advertise preformatted size, but a portion of the drive is inaccessible.
on Jul 21, 2010 | Computers & Internet
How do I add more memory to my dell dimension 3000 computer thatn has a 34 GB Harddrive?
Go buy an IDE hard drive of whichever size you want, and connect it to the IDE cable that your current drive is connected to inside the computer. If you don't want to reinstall windows, you'll have to either purchase a separate IDE cable and connect the new drive to another IDE port on your motherboard (IDE cables are the thin, flattned cables that are fairly wide) If your current IDE cable has a freed up connection, ensure that your drives are jumpered properly with the master/slave options that should be printed on the drive itself, with a diagram. Your main drive (34GB) should be the master, the new one set to slave - this will keep the computer booting off of your current hard drive. It may seem intimidating, but installing a new hard drive is easy once you open up the computer and start comparing parts, looking for your hard drive ports and power supply cables. Just make sure the IDE cable and the power supply cable are firmly attached to the new hard drive when you install it.(power supply cable usually has a white tip, with four loosely bound wires leading to it) I hope this helps!
Nov 18, 2010 | Dell Dimension 3000 PC Desktop
Will not spin
Hi thanks for asking, you should make sure your hard drive is properly connected. There are two cables need to connect to the hard drive (1) power cable (2) data cable IDE/ SATA after connected and receiving power if computer still not boot this mean your hard drive is bad and need to be replace.
Jun 13, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Nov 17, 2009 | EliteGroup K7S5A Pro Motherboard
How does the ide cable connect to the hard drive i don't see any pins for the master, i see pins for the slave I see what looks like tabs where the pins should be, do these need to be removed or is there...
The IDE cable has a connector that has a plastic notch in the middle of the connector and this matches the recess on the IDE connector socket on the hard drive. If it doesn't have a notch on the connector on the IDE cable then the connector needs to be plugged into the hard drive with the red stripe on the cable adjacent to the power connector.
The MASTER (MA), SLAVE (SL), and CS jumper settings are usually located bwtween the IDE and power connectors. The jumper connects only two pins across the rows of pins. If the hard drive is the main boot drive it is jumpered as MASTER on to be connected to the IDE cable on the first IDE controller. If the hard drive is connected on the first IDE controller as the second drive then it is jumpered as the SLAVE.
If the hard drive is connected to the second IDE controller then it can be jumpered as MASTER if nothing else in on the same IDE cable.
Oct 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Compaq Presario 5000 PC Desktop Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
