Question about Mitsubishi WS-65411 65" Rear Projection Television
Power does not stay on
When I try to power up the tv, nothing happens . The timer light flickers and then it shuts off. The tv was working earlier, my son gave me the tv and it was in perfect working condition. Only after we moved the tv to our home, now it does'nt want to power up. Any suggestions.
  • Anonymous Apr 15, 2008
    Tv won't stay on!! is this an easy fix and how much will it cost?
    President:
  • 4,402 Answers
You either have a loose connection or have bad caps.
Posted on Mar 06, 2008
  • Brian Schuette
    Brian Schuette Dec 10, 2012
    I have the same concern. I read somewhere how to fix the power supply, does anyone have this info
Same with my tv . did it get fixed and if it did how much was it.
Posted on Nov 14, 2008
The t v stays on for different amounts of time then shuts off It's a 50". Projection tv
Some TV's have a timer for auto shut off, this menu item may have been set. Check that first! Next, some TV's are negatively effected by slight imperfections in the power from the wall to the TV. I can't tell from your video but if you have too many things plugged into the same circuit, try disconnecting everything else and see if that reduces the incidents. Next, some TV's don't like surge protectors... If your TV flickers a bit before it turns off try disconnecting all other items from the same outlet, remove the surge protector and plug the TV straight into the wall, nothing else... See if that helps. If the last two items seem to help, try investing in a better surge protector.
Jan 21, 2013 | Televison & Video
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My power light flickers 4 -5 times, but the tv will not come on manually or with the remote.
my emerson t.v. model no. lc320em9 3 will not stay on. it will flicker 4-5 times and then shut off.
Aug 29, 2009 | RCA Televison & Video
Lcd tv pictures flickers on/off but power light stays on
you'll probably find the power supply of the lcd is broken. try getting a new powersupply and try to work it then
May 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Mitsubishi WS-65411 65" Rear Projection Television Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
