Hello There: Got a problem on my setup, my sound and mic/speeker jacks do not work... bought a sound card and I have sound and mic! But the mother board and computer components do not work!!! Only From The Sound Card TCK SSO JS & it's an E-Machine T3985
    Sergeant:
    Champion:
  • 277 Answers
Check the cmos setup for onboard audio and enable it
Posted on Mar 07, 2008
No sound on computer- MAG Innovision Model 468
Solution 1 It might have defaulted your sound button to mute Got to control panel Sound and see if sound has been muted
Solution 2 unplug jack out of plug at rear of computer test it in other jack holes what might have happened is that the default setting for speaker and mic might have swapped round best way is play some music and move jack plug around see if you get any sound
Solution 3 Sometimes the sound software needs re setting bring it up and re sett speekers and mike setting by the colours you have you jack in remember front and rear you will be mainly dealing with rear jack interface green pink blue white etc
hope this helps
Apr 14, 2014 | Mag Innovision Computers & Internet
I purchased a set of Logitech LS21 speekers and I can' get them to work. Below is a list of my system hardware and the steps I have done so far. Motherboard is a Gigabyte GA-MA785GM-US2H 16GB RAM AMD...
Go into control panel, then go to device manager and see Audio devices. Check to see if your Realtek is listed as your default audio device. If it isn't you have to add hardware and add the audio device using your setup disk that should of came with the computer. If the audio device is set up and working in device manager then check your cable from the mother board to the jack on the audio out that is mounted on the mother board. Finally if non of that works see if you can borrow a set of speakers to try to see if they work with your setup.
Mar 07, 2011 | Logitech LS-21 2.1 Speakers
DG965RY mother board mic is not working
HI,
there may be problem in mic hardware. Check it on some other system. It there is no problem in hardware then it should work fine there.
Else
if there is problem in driver of mic/sound card then reinstall it. Find latest one from net. and use it.
Else
if there is problem in settings of mic. Then see volume/sound card properties/ sound card software.
there is option to test mic and also to boost it.
Boosting and noise reduction options help enhancing performance of mic.
thank you,
vijay(vote for me)
Sep 25, 2009 | Intel DG965RY Motherboard
I bought inspire m4500 but only 2 speakers are working....
put the black pin of ur headphone in mic jack of laptop(mostly red color) and green pin of ur headphone in output audio (mostly green).
hope this helps u.. cheers Rajeish
Jul 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
My computer speeker is not working. There is no sound card. It inbuilt with mother board.it is intel P4. In mother board ic there this no: FW82881E8,F3300026,SL63N
Options
1. Use another speaker.
2. Locate the chip of your sound card it is near the speaker jack outlet, get the name of manufacturer(ex. via, creative, etc.) and serial number go to their site and download driver.
2. Install a sound card on the pci slot and install the driver.
May 02, 2009 | Computers & Internet
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Bad front audio jack
In most cases the front jacks are in addition to the rear ones. It's not an either/or situation. If the speakers are connected to the rear jacks (usually green for speakers and pink for mic) and there is no sound, you might have a problem with the onboard sound. Try connecting to the rear jacks with a good set of speakers and try it out. If this doesn't work then we can go from there.
Dec 29, 2008 | E-Machines W3107 (RBW3107) PC Desktop
Not getting full 5.1 sound from PC to surround sound system
well if your motherboard supports your speekers it shoud run corectlly, but if not, you shoud get a special sound card with cd, which will allow you to use your speakers. if you already have that sound card and installed drivers you should go to your sound card control pannel and make changes there to use all your sound system speakers.
Dec 29, 2008 | Computers & Internet
Creative HS-400 headset & Mic
I had the same problem... with my laptop, using vista. I plugged the mic dirrectly into my laptop and for some miracle, it works! try it out! ^-^
Sep 25, 2008 | Creative Labs HS-400 Headset
Computers & Internet Logo
355 people viewed this question
Alun Cox
David Payne
David Payne
