Go to "My Computer" and click on the V-Touch (named Removable Hardware) and open the "Music" folder. Click on one song you want to play or highlight multiple songs that you want to play click open and they should open in Windows Media Player, if its your defalt music player.
Hi, your ipod displaying data and not playing might be because you did not transfer the music properly or the format of the music does not play on an ipod.
You will need a converter to help you convert songs into an ipod format. Download from the below link:
effectmatrix.com/total-video-converter/
You can follow the instruction below to know how to transfer music into an ipod.::
Most common problem for new ipod user is how to put music onto ipod. So I created this ipod tips to solve this problem. Windows media player is not able to upload songs to ipod. You must use Apple iTunes to get music onto your iPod. Windows Media Player can see the iPod as a hard disk. But not able to copy upload music from pc to ipod.
The steps to put music onto an Apple iPod with itune. When you plug ipod to your pc first time through USB, you might get this pop up message. If you have already installed itune .
You need to restart your computer to install ipod and then the next time you start up, your iPod will not generate any messages of this nature. You need to install itune on your computer if you have not installed itune. You can simply go to apple.com/itunes to download the latest version. It also comes with ipod CD. The next step is to launch the iTunes program. And it will recognize the ipod that you have plugged in
It shows one message to give name to ipod, You can stick with the default name for your device or give name to ipod. I also uncheck "automatically update music" because I like to control what happens to my iPod manually. When you're done with this configuration step, click "Next" : register your iPod, or just click "Finish".
Step 1
Now, finally, you can see iTunes and also your ipod inside your itune: Click on whatever name you've given to your own iPod, and you'll see your music list, which is completely blank:
Now click on the "Library" link on the left column and you'll see what albums or music you've copied into your iTunes library. Or click on the "Browse" button on the top right (it looks like an all-seeing eye) and a new panel will show up with lists of songs, artists and albums.
Now select the song you want to put on to your ipod. then dragging and dropping that onto the name of the iPod on the left side panel of your itune. Now your song are copied to ipod.
you have to go to the music icon on the main screen. click it and then scroll down to "add to audio list" press "upward directory" the "music" pick the song you want click it, it will bring you to the name of the album. click that and it will show the song, click that. a little screen should pop up and say "sucess" it will then show up in your song list under the music section. you have to do this for every song.
When you installed the songs all you installed was the title. I had this problem with my rca pearl,
you must downlad the song and not just the title of the song o.k.
Try again with the whole song.
when you put your cd's together put them as a playlist
It could be the wrong format. I used to play music off my psp. I'm guessing if you use iTunes, and imported a CD, its going to make your songs AAC format, which is also known as MP4. I have posted a link to where you can set the different compression methods. If you are using WMA format, you are using an even less compatible format, and if you import it into iTunes, it will convert it as well. To convert already imported music into iTunes, once you set the preferences to MP3, right click on the song, and click "create MP3 version." after that you may reveal the song in the finder/explorer by right clicking the song, and clicking "show in finder" or "show in explorer"
Look in the music folder (top left of the main itunes page). You should see all of your songs there. If they are there, then plug in your ipod, click on the name of your ipod (left hand ide of the screen) and check the box on the main screen that says (manually manage music). Then go back to the main music folder again, and select all of the songs, (you can do this by clicking on the first ong in the list, hold down the shift key and then click on the last song in the list), then drag and drop all of the songs onto your ipod in the list at the left.
