Question about CyberPower 1350VA UPS w AVR & LCD (CP1350AVRLCD) UPS System
Backup unable to communicate with computer
Tried checking all the connections and all seem to be fine.
If I push the button the the front of the cyberpower machine it turns off my computer and runs through some stuff and then when I turn the computer back on the ups goes off again and I get the 'unable to communicate' message again.
  • jmismo Mar 13, 2008
    The solution was that I didn't have the cable hooked up to the computer for the online program. My UPS was running fine I was just confused by the message that it wasn't communicating with my computer. I thought that meant it would not come on line when I had a power failure when what it means is that I can't track the condition of the UPS online. Thanks to all who helped.
  • 151 Answers
Plz check your computer without ups.If it is runing there.And wattage of ups .It seem over load or shortage of ups.Check power cable.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 08, 2008
My computer states that it is unable to communicate with UPS why is that
When computer is turned on, that is what pops up unable to communicate w/ups.Everytime
Apr 25, 2012 | CyberPower CP425G Uninterruptible Power...
Unable to edit setting
Hi. You can try the following steps to get this working
1. Uninstall the software.
2. Download viersion 7.7.0 from http://logitech.com/myharmony.
3. Install.
4. Uninstall the Logitech Desktop Messenger.
5. Disable any firewalls you may have on your computer.
6. Run the software, and connect your remote.
7. Click "Replace Remote" to conduct a connectivity check.
Also, ensure that you arte not using a wireless network, and that your remote is connected right to your computer, not through a USB hub.
Nov 17, 2009 | Logitech Harmony 670 LCD Remote Control
BenQ computer start button doesn't work sometimes
Recommend replacing the switch with a new one. Usually the button is just a cover and mounted on the Chassis face. The real switch is behind the plastic button. You'd probably have to remove the front panel or go inside the Chassis to get at the switch. The switch will have a couple of wires that connect to the mother board "Start" pins. The wires can be unplugged from there.
Jun 10, 2009 | Computers & Internet
Canoscan Lide 60 suddenly cannot be communicated.
hi um i don't know if this will actually work but it did for me, I had 2 problems with the lide 60 scanner-one was a connection/cable thing and another was this "TWAIN source thing" and after installing this:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
i seem to only have one....i think the connection/cable got fixed.
oh well, give it a try anyway :) cant hurt
Mar 11, 2009 | Canon CanoScan LiDE 60
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
APC communication error message
Try going to the properties of the driver and select do not check or check every X mintues.
Try this thanks J
Dec 13, 2007 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
CyberPower 1350VA UPS w AVR & LCD (CP1350AVRLCD) UPS System Logo
498 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
David Payne
David Payne
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
