Question about HP PSC 1510 All-In-One InkJet Printer
Ink levels How do I find out how much ink I have left in the cartridges ? I have a HP PSC 1510
  • Anonymous Apr 07, 2008
    What tabs do I click to find this?
Open the printer preferences, click on the services button, locate "Ink Levels" and voila!
Posted on Mar 08, 2008
2 Suggested Answers
edmacias
  • 70 Answers
SOURCE: how to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Posted on Nov 25, 2009
Refill
You have to reset the cartridge chip with a special device that resets the stored ink state data.
Jan 26, 2014 | HP PSC 1510 All-In-One InkJet Printer
What is the model of inkjet cartridge? Is it 0I-HP C9362(92)? coz i cant install in the ink, thx for reply!
Your printer uses the following ink cartridges:
  • HP 92 Black Ink Cartridge (HP part: C9362WN#140)
  • HP 93 Tricolor Ink Cartridge (HP part: C9361WN#14
  • dentifier"><span class="type">SKU</span> <span class="value">C9361WN#140</span></span>HP 99 Photo Ink Cartridge<span class="identifier"><span class="type">SKU</span> <span class="value">C9369WN</span></span> (HP part: C9369WN)
Jun 13, 2011 | HP PSC 1510 All-In-One InkJet Printer
HOW DO I CHECK THE INK CARTRIDGE LEVELS HP PSC 1500
You can check it on the settings>Ink levels on the printer software
May 14, 2011 | HP PSC 1510 All-In-One InkJet Printer
How to change ink cartridge on hp psc 1510
Cheers, Ed
Nov 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
My HP PSC 1510 will not take refill cartridges, - B/w and Color lights flashing
the cartridges are damage or not the right ones for your printer. first make sure you clean the cartridges before installing cos ink on the cartridge (panel) can stop the printer from detecting it.
Jul 01, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do i get the ink levels on my HP PSC 1510 All-in One printer?
Go to start, parameters, printers chosse the printer click right mouse button properties....usally you will everything there
Feb 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink lvels
Hello holliston,
You can try the following steps that should help you determine your ink levels.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Sep 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
186 people viewed this question
Ben Johnson
