Question about Citizen CBM 1000 thermal Printer
ERROR LIGHTS My printer beeps 4 times on startup and the Error light flashes 4 times and then goes solid (cycles). Is there a way to reset the printer?
Go to this site for help on light/beep codes.
http://www.goodson.com.au/download/manual/cbm/user/CBM1000II%20User%20Manual.pdf
Posted on Apr 06, 2008
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
Canon i475D is showing error 807
This is basically ink tank error.
You have to reset ink tank
1.Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Thank You
Nov 22, 2010 | Canon i475 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Resume light flashes and beeps. Lost its mind and
    Try this:
    F14 Error Reset
    1: Unplug adapter
    2: Hold POWER
    3: Plug in ADAPTER
    4: Release POWER after printer starts
    5: Hold FF and MENU and press POWER
    6: Release after beeps
    7: Press <> Cartridge until 1D is displayed
    8: Press ONLINE
    9: Press POWER to shutoff printer
    10: Unplug printer then replug printer
    Jun 15, 2009 | Canon BJC 80 InkJet Printer
    Brother HL-2040 toner light stays on
    I found this and it worked great.
    1. Power Unit off
    2. Open front cover
    3. Press and hold GO and turn power on
    4. When all 3 lights lit release and press GO twice
    5. All lights turn solid
    6. With all solid, press GO 5 times
    7. Ready light GOes red
    8. Close door and you're all set
    Mar 17, 2009 | Brother HL 5250DN Laser Printer
    Cannon BJC 80
    5 times try this:
    1: Unplug Power Cord
    2: Hold POWER and RESUME buttons
    3: Plug in Power Cord
    4: Release buttons after the printers starts up
    5: Hold CARTRIDGE and RESUME
    6: Press POWER
    7: Release all buttons after the beeps
    8: Press CARTRIDGE 16 times
    9: Press RESUME
    10: Unplug the Power cord
    3 times, probably something wrong with the cartridge.
    Nov 21, 2007 | Canon BJC 80 InkJet Printer
    Canon BJC 6000 Beeps and Power Light Flashes Orange
    The 6 beeps along with the orange light stands for "Re-install BJ cartridge or replace it". You might have already fixed the problem by replacing the cartridge, and you're still stuck with the error indication. Waste Error Reset 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data If it still doesn't go away, try cleaning the contacts the cartridge makes with the printhead. Dip the carts contacts(dipping only the contact area) in shallow hot water for a minute, then wipe dry with a cloth that doesn't shed fiber. Also clean the contacts on the printhead using a damp cloth, maybe also some alcohol. If it still doesn't go away you have to think of replacing the printhead, or chucking it. Good luck
    Jun 20, 2006 | Canon BJC 6000 InkJet Printer
    Citizen CBM 1000 thermal Printer Logo
    711 people viewed this question
    Top Citizen Office Equipment & Supplies Experts
    jay kaye
    jay kaye
    Roy May
    Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
