Question about Zanussi ZWF1440 Front Load Washer
Machine will not operate
Machine when set to operate makes appropriate sounds for about 20 seconds then shuts down to display end of programme, this happens on all settings including spin. Anyone got an idea what the problem is?
Many thanks John D.
  • 96 Answers
If you are getting a flashing "0" and a buzzing sound it means you needed to hit the Skip/Reset button at the end of the last program. Shut everything off, then hit the Skip/Reset button a few times and then put in a new program and see if it works.
Posted on Mar 07, 2008
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
The machine does not respond to any programme. The spin selection display flashes the 800, 600 and rinse stop led's simultaniously. None of the buttons on the machine is responding when pressed or hel
If this is a front loader and there is a pump filter, pull it and clean it out. Mine is located on the front behind a small access door down by the floor. Be prepared for lots of water since your tub is probably full. If it can't pump the water out fast enough (filter plugged) it will become out of balance in the spin cycle and shut down. After you to this unplug the machine for 30 seconds, then plug back in to reset the electronics.
Jan 23, 2015 | Washing Machines
SC5 D-1 Stairmaster cosole issues
Sounds like you just need to configure your console to the appropriate machine
1: Press LEVEL UP, 8, and ENTER and the console will display CONFIGURATION.
2: Press LEVEL UP or LEVEL DOWN to scan through the choices.
3: Scroll through the screen until CHANGE MACHINE is displayed. Press ENTER to select the appropriate machine.
If this doesn't resolve your issue please do not hesitate to contact our Technical Support Team online or by phone,
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Apr 30, 2014 | Stairmaster SC5 Commercial Stepper D1 LCD...
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Kenmore 110 washing machine thermally cycles
Does it operate properly if you or something holds the switch down? If yes, then extend the end of the lid switch with hot glue, epoxy, or silicon glue to allow the switch to be pressed sown further. You can also build up the contact area under the lid if you choose--same result.
Aug 07, 2009 | Washing Machines
Machine is completly locked
I just had the same problem! I put the dial to 6pm and held the start key down for about 20 seconds and it re-set itself!
I did clean the filter too!
Dec 06, 2008 | Bosch Washing Machines
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Cycle will not start
sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
Aug 07, 2007 | Baumatic 18 in. BFD46 Free-standing...
Zanussi ZWF1440 Front Load Washer Logo
130 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
