Question about Electronics - Others
Logging into my memory stick
I have a verbatim memory stick when i try to log into the security side i get a message saying is not valid win32 application can you please help
  • 30 Answers
If you are running windows vista, try right clicking on the locker -select properties-select compatibility tab- check mark the run in mode box and run the application in windows xp service pack 2 compatibility mode or another mode listed. If this doesn't work then your drive might have become corrupted, either from static electricity from being plugged/unplugged with your computer on, or coming too close to a magnet etc... Always back up your data. Good luck.
Posted on Mar 15, 2008
Every time i try to log in to fb, the page starts loading but then i always get deferred to a page saying "you must log in to see this page" . Sometimes it even says that my password is wrong...
Kindly check the email address you used in logging in to Facebook, is it a valid one.. also checked if you have hit the caps lock key in your keyboard, this can also cause wrong passwords.. :)
or if you want me to check your account, kindly pm me.. :) thanks!
Feb 03, 2011 | Facebook Social Network
Being logged off everytime.saying somebody logged on in a different computer
have you logged in somewhere else recently ?? change your password so that if you have signed in elsewhere the saved password on that machine will no longer be valid !! problem solved
Dec 09, 2010 | Yahoo Messenger
I cant switch on my phone nokia3110c , every time i tried to switch on it says CONTACT SERVICE
hi,
your phone have a software problem and its cause is "security test failed"thats why it has a contact service status...by fixing that you need this gadget ...
1.mx key activated dongle with ufs interface
2.3110c fbus cable (same as 3500c and 6300
3.)modified pm 1 and 309 of 3110c
procedure...
a)open mx key
b.)connect the phone to mx key using fbus cable
c.)in mx key select bb5
d.)bus check and you you will see this logs
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
in this logs you will noticed that security _test is the only failed...
e,)we will continue by selecting PM then thick PMM authentication
f.)then your pm now is authenticated ,write the modified PM (by writing modified pm ,thick load from file ,then write)
g.)after writing PM here now is your phones logs...
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
h.)now you need to unlocked the phone by clicking ,SERVICE ,IMEI and SECURITY then INIT SIMLOCK...and you phone is done
always remember ,when doing software action to your nokia phone ,always back up the rpl to prevent more damage..thanks for trusting fixya..
Jun 19, 2010 | Nokia Cell Phones
Facebook log in problem
you opt for get exemption by getting SSL certificate on the spot while showing error in web.. you may easily complete about these functions in Mozilla firfox!
Dec 17, 2009 | Computers & Internet
2log(base4)x + log(base4)3=log(base4)x-log(base4)2
It is easier to use the rules for logarithms to clean this equation before trying to solve it. And the calculator is no help here.
Let me represent the logs as follows log b in base a = log(a,b). The first argument is the base.
2*log(4,x) - log(4,3)= log(4,x)- log(4,2)
Here you have two similar terms 2*log(4,x) on the left and log(4,x) on the right. Gather them both on the same side, say the left. You have
2*log(4,x) -log(4,x) +log(4,3) = log(4,x)-log(4,x) -log(4,2)
which is equivalent to log(4,x) +log(4,3) = -log(4,2)
Gather the constant terms on the right, and use log(a) +log(b)=log(a*b)
log(4,x) = -log(4,2) -log(4,3) = - { log(4,2)+log(4,3)} = -log(4,2*3)
You get log(4,x)= -log(4,6).
Take the constant term to the left, while changing its sign in the process. On the right remains 0, which is also the log of 1 in any base So log(4,x)+log(4,6) =0 =log(4,1)
Use the rule log(a) +log(b) = log(a*b) valid in any base, to obtain
log(4,6x)=log(4,1) which is equivalent to 6x=1. The solution is x=1/6
There are a few other shortcuts to get the solution but I preferred to take a pedestrian, step by step, approach.
Hope it helps.
Nov 25, 2009 | Casio FX-300MS Calculator
Verbatim 1gb flash drive privacy zone lost space
try this link. http://verbatim.com/support/support-article.cfm?support_id=807E395C-1422-1392-A886DB00B24DFF68&supportType=Download
Aug 13, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Wireless problem
its windows. nothing to do with the software. after you removed it. its long gone. Check the wireless and the OS settings
Jul 25, 2008 | Belkin (F5D7230-4) Router (587009)
Computer crashed
that is a memory dump, try to remember what hardware or software did you install or uninstalled recently, if you can log-in on windows try uninstalling or reinstalling the hardware or the software. if it fails, run the windows recovery on the cd and repair the windows installation.
Feb 18, 2008 | Dell Inspiron 6000 Notebook
Verbatim Thumb Drive problem
You may need to log on to the computer with administrative privileges. Ask your friend to log you into the Administrators account, then insert the drive.
Sep 02, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Electronics - Others Logo
63 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
