Devant LCD TV: Characters appearing on the screen while watching
Hi.. i have a problem with my Devant LCD TV. While watching TV on cable, there's a character randomly appear on the screen. Please kindly help me on my problem. Thanks.
Using a VGA splitter to connect a laptop to a Devant TV can work, but it's important to note a few things:
1. **VGA Splitter Compatibility:** Ensure that the VGA splitter you're using supports the resolution and frequency of both your laptop and the Devant TV. Some cheaper splitters might not support higher resolutions, resulting in a lower quality display.
2. **Connection Setup:** Connect the VGA output from your laptop to the input of the VGA splitter. Then connect the two outputs of the splitter to the VGA inputs on the Devant TV.
3. **Settings on Laptop:** On your Mac, go to System Preferences > Displays. Ensure that the display settings are configured to extend or mirror the display to the external monitor (TV). You might need to detect displays or choose the appropriate resolution settings here.
4. **TV Input Source:** On your Devant TV, select the correct input source where you've connected the VGA cable.
5. **Signal Quality:** Be aware that using a VGA splitter might degrade the signal slightly, potentially impacting the quality of the display on both screens.
Remember that VGA is an analog signal and may not deliver the highest quality resolution compared to more modern digital standards like HDMI. If both your laptop and TV have HDMI ports, using an HDMI cable might result in a better quality connection.
Hi Emma,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
- Flickering screen
- Dim screen
- Slow start
- Flickering screen
- Dim screen
- Slow start
Hi:
First thing is to determine what type of video connection you are using to watch TV. If you use componet video cables to watch tv check teh green cable to make sure its connected also check the red and blue because if the green come off the picture will appear B&W
