Sony Laptop screen problems
Sony vaio laptop 6 yrs old - sceen stopped working - not the graphics card as external screen still works when plugged in...is it worth getting repaired and how much aprox to get it fixed
    Novelist:
    Champion:
  • 256 Answers
You might see the presence of random lines all over the screen in some occasions in your sony Laptop. Often, troubles are created due to this. You would see the vertical and horizontal lines. You could solve this problem easily with the help of LCD BIST test. For this you would have to press the function key and follow the instruction as the LCD BIST runs several colored screen.
Posted on Sep 28, 2011
    Genius:
  • 1,019 Answers
I always think Vaios are worth Repairing.
If It,s An FX model Or F they,re a great Machine. P3 were the Most reliable Processor Made ( in My opinion )
I see Sony-Vaio As the rolls-Royce Manufacturer Of Laptops.
Therefore i would suggest Purchasing a replacement Screen.
It,s not that difficult to replace. With A service Manual ( e-Bay ) you,ll get a Screen 14" Or 15" Depending On Model. For About £80-£140. for a laptop that Probably retailed At Over £1000.00 in it,s day. i,d say go for it.
I have several replacement Screens myself, if your in the UK.
i,d offer you a full replacement Screen Fitted On your item.
Mike @ Compurepair.
Posted on Mar 06, 2008
Not getting video (blank screen) on my Sony Viao E series laptop.
Your friend is wright, this is a graphic card problem.
most laptop have the graphic card integrated and cannot be changed.
in your case check this link http://community.sony.com/t5/VAIO-Hardware-Networking/CAN-I-REPLACE-GRAPHICS-CARD-OF-MY-VAIO-LAPTOP-E-SERIES/td-p/164377
Thanks.
Nov 02, 2014 | Sony VAIO E Series Notebook VPCEB1GGXBI
I have a sony vaio sz120p and the sceen went dead. I narrowed it down to the video card being blown. It is a Nvidea go 7400. I need to know if this is an MXM board and what size. and also if replacing the...
The motherboard will be a sony board. They do not use outside manufacturers for those. The video card is part of the motherboard so you have to replace the entire board.
Before you go replacing boards or junking it have you checked to see if the problem is the back light or back light invertor board? That is far more common than a actual failure with the video section. You can do a few simple checks. First turn on the vaio and look close at the screen if you see a ghost image that looks like your windows screens (It should move etc) then your back light is out or the inverter board which powers it is. The other thing to try is plugging a monitor into the laptop. You may have t o enable it by hitting FN-F7 I think on the Vaio to switch to the external monitor unless it is set to auto. The proper key will have a little monitor icon on it. This will test your video section. If the external works the problem is the back light again and the video section is fine.A back light is under $50 in part to replace. A motherboard for some Vaios will hit $350 even from a third party parts place.
I've repaired Toshiba and Sony laptops for several years now and could count the dead video on one hand with a few left over fingers. It really is uncommon to say the least. A back light is one of the most common failure for any lcd type device, laptops being no exception.
Sep 17, 2011 | Sony Computers & Internet
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
I have a sony vaio vgn cs36gj and on the start bar there is a line right across the bottom that flickers every five seconds. I have my screen adjusted to the correct resolution. I have also plugged in an...
90% chances are that this is the problem with your Graphic settings.(go to your Graphic Properties and make sure that Refresh Rate should not be more then 60Hz). Change it to 60hz and restart your machine, This should resolve.
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 28, 2010 | Sony VAIO VGN-CS260J/P Laptop
I have a sony vaio laptop and the screen has all lines on it,what could it be?
Hi:
It is most likely the LCD assembly, but to eliminate other possibilities, connect up a desk top monitor to your laptop, and toggle to the external display and check the picture on it. If it is good, then your LCD is bad, if the picture is still bad, you have on board video problems, and not easily fixed. To toggle to the external display mode, you usually have to hold down the function key and hit the function key with a picture of a TV screen on it.
Apr 20, 2010 | Sony (1-761-035-11) Graphic Card
Sony Vaio Laptop PCG 9U1M
PCG-K415B is the correct model number the label is possibly the service tage or something.
Here are the specifications of your laptop
  • Intel Celeron D Processor 345 3.06GHz / 533MHz FSB
  • 512MB DDR SDRAM - Low cost double memory Offer - call for details
  • 40GB Hard Drive
  • DVD Dual Layer Drive - To read DVDs and CDs and write CDs, DVD+, DVD- and large Dual Layer DVD
  • 15.4" XGA xblacklogo.jpg Widescreen TFT Screen
  • ATI Mobility Radeon 345M 64MB shared graphics
  • Integrated wireless 802.11b/g LAN - Call for advice on Wireless networking
  • Integrated 3-in-1 card reader –Memory Stick, Memory Stick Pro, Memory Stick Duo
  • Operating System: Windows XP Home Edition
  • Includes Sony Software Bundle
My guess is that the laptop is around 1 or 1and half year old as the celeron 3.06GHz is a relatively new processor.
May 26, 2009 | Sony VAIO VGN-AR230G Notebook
External Hard Disk not detectedin SONY VAIO
Did you mean the External HDD with USB plug was not detected in your laptop but desktop?
Nov 19, 2008 | Sony VAIO GRV680 Notebook
ATI Mobility Radeon? X2300 graphics driver for Fedora
If you install the Fedora 9 preview it should resolve this issue.
May 02, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
91 people viewed this question
Alun Cox
David Payne
David Payne
