Question about Frigidaire FEF336BC Electric Kitchen Range
The other day , the small element front left one broke , as there was a big spark as well. Now this part of the stove is not working but the other three elements are working. My problem is if I insert the other wroking element in there to check , still it is not working and at the same time the pilot light is on all the time on this side, even if I on/off the big element on this side. What should I look for and or repair besides replacing the element.I have this stove FRIGIDAIRE MAKE-SPECIAL EDITION.THANKS.
  • inder307 Mar 17, 2008
    Thanks for the solution-please advise how to reach the defective infinte switch and repalce it with the new one- once I am there I think I can fix it and also will replace the defective wire if any.
  • inder307 Mar 18, 2008
    thanks.
    President:
  • Frigidaire Master
  • 2,651 Answers
I would replace the infinte switch behind the knob, the element(if damaged.the switch appears to have shorted out !!! a few wires no prob. maybe 40 bucks for the part
Posted on Mar 16, 2008
  • Ron Coons
    Ron Coons Mar 18, 2008
    pull the unit out from counter, reomve maybe 6 screws to drop back upper panel.TURN POWER OFF FIRST!!!!!!! all hte switches are located back there,
I was cleaning my oven and there was a small pop and spark where the top element attaches to oven. The entire stove is now dead. The breaker was tripped and I reset it but still nothing. Any ideas?
You need to replace the element. The elements wear with time and get thinner. When they go, it is exactly as you describe. Some older stoves have fuses behind the front panel.
Nov 19, 2016 | Kitchen Ranges
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
A small piece of kitchen stove element broke off and exploded.
Hi, There is no sure reason. This just happens. The element had a weak spot on it and finally gave way. Change the element and you should be fine. I hope this helps. Anything else I can assist you with, plesae let me know.
Thanks
Vic
May 14, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Bake element got white hot and sparked
your element burnt through it will need to be replaced
Apr 02, 2009 | Electrolux Kitchen Ranges
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven does not work
somthing shorted those are easyer to repair because theres evidence some where.turn off power and surch 4 that burnt spot then repair accordingly.most common on electric stoves are the element shorting you would see blistering on the element.God bless,tom
Jan 01, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Frigidaire compact 30 elec. stove. I need a wiring diagram for the front connections for oven, burners, oven lights. My oven isnt working and when I removed the front cover, noticed a wire not connected. ...
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Sep 19, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
94 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
