Question about RCA D52W19 52" Rear Projection Television
1994 RCA P52753 Rear Projection
All the colors have turned to either pink or green. I can't fix it in the menu any more. Can this be fixed?
  • RobinLynn55 Mar 07, 2008
    Are you saying that the speaker panel on the front of the TV needs to be removed to gain access to these controls? Oh, and when I turned the color all the way down, like you said to, all it does is turns black and white. Isn't that what it's supposed to do when you turn the color all the way down? Your words were confusing in the way that you typed them.
  • 61 Answers
Sounds like the screen asy has failed causing the color to change from black and white,turn your color all the way down and see it the picture is green,blue,or red,if so the asy is bad or the tubes are getting alittle weak,the asy is in front of the set behind the speaker grill,there is a access panel to remove and the asy has 6 controls to adj.,only move the ones that are marked screens below them,this asy is black and is only 4 inches square,do not move any adj. on the tubes
Posted on Mar 07, 2008
All of a sudden the top of my TV picture went pink and green, pink and green colors over lap and make it look blurred. Tried aligning colors but green on graph are wavey.
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 25, 2011 | Hitachi 51F500 51" Rear Projection...
I installed a new color wheel in my RCA 50inch DLP TV but now the facial tones are now purple. I believe I need to somehow index the wheel using a service menu but do not know how to access it. The TV...
This might help ,the Fix for Pink Picture on another Set was to replace the Formator Board and the DVI Cable .
Formator Board PN# 263247
DVI Cable PN# 263254
The way to Enter Service Menu for most RCA is to turn TV off, Then Press and Hold at same Time
CH- and Vol- wait untill TV turns on then release and Service Menu should come up.
Encompass Parts Distribution 1-800-638-3328 they might have the Parts you need.
Jan 14, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
My tv is having a pink and green lines. It looks
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Dec 27, 2009 | Philips 55PW9363 55" Rear Projection...
Pink and green at top told needs to be aligned
More likey you have a convergence problem. Goto www.TvRepairKits.com for examples.
May 12, 2009 | Philips 55PW9363 55" Rear Projection...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Seeing Double
What do the menu looks like?
Aug 09, 2008 | Philips 60PP9202 60" Rear Projection...
Hitachi 60SX8B9K
Classis convergence failure - goto www.TvRepairKits.com to get a kit to fix this yourself
May 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Green color
Hi...this could be the colorwheel. Very common in this model and an easy fix too.
Mar 20, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
