Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has rock, marble, or something stuck inside
There is a foreign object of some type inside the machine. I can hear it when the machine is washing clothes, and when it gets to the final spin cycle it is the loudest sound I have ever heard. I had Sears come out yesterday and they reccomended replacing the drum for $473. Any suggestions?
  • 2 more comments
  • kpaller Apr 13, 2008
    I've had mine for 1 week now - and it sounds like a pebble is in there! Maybe like a ticking noise? Once it really gets spinning the noise stops though - Not sure what to do -
  • dthom4102 Jul 15, 2008
    Same problem, something is stuck in between the drum or something. Very loud on final spin cycle.. How do I get to it?
  • Anonymous Jul 19, 2008
    We think there is a rock or a marble in our washer and are not sure how to get the drum out to check and remove it. How do we do this?
  • sleblanc Jul 19, 2008
    Loud noise during the spin cycle - sounds like a marble. Don't know how to remove the drum to get it out.
    President:
  • Whirlpool Master
  • 2,651 Answers
As long as your sure its an item between the tub assy the baffles in the drum can be removed and item fished out. but ifsomething snapped on the rear of the drum you would need to replace it. the baffle part number is 8182233, its about $40 thinknin thats worth a try before 475. the lower acess panel could also be removed and the main tub to pump hose could be removed which would give you a 3in hole to look through and try to grab somethin. worth a try
Posted on Mar 07, 2008
  • Jeff Feb 06, 2012
    I have removed the lower access panel and found access to main tub to pump hose but unable to remove the silver brackets that is holding the hose to tub, any help or special assistance on how to get this rock, pebble, pen or something out of my final spin,
  • Jeff Feb 06, 2012
    I got the lower access panel off but I am having trouble removing the pump hose, any special tools or ideas?
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
Aug 31, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not spin!!!!!!!!
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin.
1.) A coin or other foreign object could block the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch before the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers or vice grips will work.
If the washer will not agitate during the wash cycle you will need to remove the back panel to inspect the belt and spider pulley. You will also notice a counter weight at the top of the tub. Make sure the counter weight is tight and is not loose to prevent future problems.
Feb 17, 2011 | Frigidaire GLTF2940ES Front Load Washer
I'm having a problem with my frigidaire front loading washer. It is not draining all the water out when cycle is done. Water left standing in washer.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Jan 06, 2011 | Frigidaire ATF6000ES Front Load Washer
F2 is flashing washer wont start
the F 02 errors in these machine means "Long Drain". 9 times out of 10 this is an issue with the pump. Pump problems plague these machines, not because they are faulty, but because things get inside them. Foreign objects like pencils, paper clips, etc. Generally you can remove the obstruction and resume using the washer. If you are unlucky, something damaged the pump and it will need to be replaced. Naturally there can be other causes to an F2 error, but this is the most likely.. by a loooooong shot :)
If you are a do it your self type of person, I can tell you how to take care of the pump yourself. This would require some tools and might get a little messy tho. Glad to help either way!
Depending on where the pump is purchased, it can cost anywhere from $120 - $200. good luck!
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't spin
Jan 18, 2010 | Frigidaire GLTF2940ES Front Load Washer
F21 Whirlpool duet washer, removed front panel unclogged restarted and still f21? Tech came in and had no idea said he smelled something burning, must of been his imagination.
ohh, duets are such a treat.
If the drain time exceeds eight minutes, “F21” will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
this is what Whirlpool says, but we have found that this doesnt always work.
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing f- 21
F21 means “long drain” – takes too much time for the water to get out. Check the drain hose and make sure it is not clogged or kinked. Check the drain pump filter for foreign objects. Check the electrical connections to the pump and make sure the pump is running. Check for foreign objects inside the pump. If it doesn’t help, replace the pump. To clear the display press PAUSE/CANCEL two times. Good luck.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,316 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
