Question about Refrigerators
Kenmore Refridgerator model 10656566400 Ice Maker not working
The water valve for the ice maker works when I swap the water connector to the ice maker solenoid and activate the water dispenser. I disconnected the ice maker water tube and blew air through it so it is not frozen. The optic sensor flashes 2 times and then pauses and repeats (is this a vault code and if so is there somewhere I can get the codes descriptions?). When I close the flapper door it remains a steady red.
I pulled out both sides of the optic sensors and cleaned the lenses. The temperature is set to 0 degrees but the ice maker still does not work. How can I test the emitter and receiver boards. The connector on the left side (P/N 2220398) has 4 wires (black, brown/white, Orange/black, white) and the right side component (2255114) has 7 wires (White, Yellow, black/white Brown, Brown/white, orange, black). How can I jump them to test the boards?
  • tntkbt Jul 26, 2008
    ice maker' no ice light inside freezer door flashing like a code
  • Zendog Sep 30, 2008
    My Kenmore ColdSpot (ame model) is also giving me a flashing code that indicates that there is a problem witht he optics. However they are not blocked or iced over. I got the code desciption from behind the kick plate grill on bottom near water filter.
  • 3 Answers
Check out this site it might give some helpful information..
http://fixitnow.com/appliantology/typeoicemaker.htm
Posted on Sep 08, 2008
The two blink signal indicates that the level sensor is blocked. If you hold the little door that senses the ice bin inward or closed since it flips out when you open the door, you should get a solid light on most models. So if you are getting this solid light, you sensor is working properly. If you close the little door and the lamp continues to blink, then your sensor is at fault. If it is solid light, then your freezer may not be cold enough. Check the temperature of the freezer.
Posted on Jul 29, 2011
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
CAN13 ice maker does not call for water.
Ice maker is bad if not sending power to valve.
Oct 14, 2017 | GE Refrigerators
My ice maker quit making ice the other day. I finally got under there and checked everything out and it all seems ok. The problem looks like there is no water coming in from the supply line. Why would...
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it's getting power it should click when you try it and water come out.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 18, 2011 | GE Profile Stainless Bottom-Freezer...
Water is not getting to the icemaker. however, it is dispensing at the glass tap
Water inlet Valve
Dec 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an electrlux modelGLHS36EEB5 fridge.I changed the filter but the ice macvhine won,t start again even after pushing and hold the button for the colours
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it’s getting power it should click when you try it and water come out.
Feb 10, 2010 | Refrigerators
Not getting water to the ice maker on my Roper refridgerator.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Feb 10, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
No ice from icemaker model kenmore number of fridge is 106.56152500
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 17, 2009 | Kenmore Refrigerators
I have a refridgerator model 106.56664500 and it has stopped making ice. Can u help..
Sep 12, 2009 | Freezers
Kenmore refrigerator side by side ice maker not making ice.no water going to the ice maker??.
Sep 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stoped working
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
1,086 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
