Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Vacuum belts how do i put a new belt on my vacuum?
  • Anonymous Apr 03, 2008
    Replacing belt
I can't do it
Posted on Mar 22, 2008
    President:
  • 1,673 Answers
Take off the bottom plate, there are 2 belts, the V belt (38528034)goes on first, it goes around the pulley then around the brush roll. The Flat belt(38528035), put it around the motor shaft first, then stretch it to go over the bigger pulley.
Posted on Mar 06, 2008
3 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: BELTS ON WINDTUNNEL VACUUMS
Greetings from GoVacuum,
Here's an instructional video that we made showing how to change the belt on a Hoover Windtunnel upright. If your model is not a self propelled model, basically follow the same insturctions, expect instead of placing the belt over the pulley, just put the belt through the roller brush, and stretch the roller brush back into the agitator housing.
Please feel free to send me an email if you have any other questions. My email address is chris.jones@govacuum.com.
Thanks,
Chris Jones
GoVacuum.com
Posted on Sep 29, 2008
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum powers off and when I check the NEW belt, it looks frayed.
There is misalignment of the belt path. This can be a result of uneven wear of the brush roller.
Jan 15, 2014 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Mom has a Dirt Devil Featherlite and the belt falls off all the time. I put it on three times today and it falls off within a few minutes. The belt post I put it on doesn't have anything to hold the...
It sounds like the belt is too worn and loose to stay on. Buy a new belt specified for that model of vacuum and install. Ensure that there is only a slight amount of give in the belt when you press the middle.
Jan 05, 2011 | Dirt Devil CE6100 Featherlite Upright...
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
How do I change the belt?
Turn the vacuum over so the bottom is up.. Remove scews from plate surrounding the brush area..
Pop of the cover plate..
Lift out the side of the brush that the belt connects to..
Put new belt on..
Put the brush back in place.. It might be a bit tough because the new belt will have a bit of tention..
Put plate cover back on and screws..
Jul 28, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do I put a new belt on Hoover Concept One vaccume cleaner?
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
May 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot fit a belt to hoover whirlwind
on the top of the base you will see three slots on each side of the top of the base the middle slot has a screw one on each side take those out and the cover will lift off.you will be at the roller and belt.lift up on the roller and put it on the side .you must clean the old rubber left on the motor shaft first before installing the new belt.otherwise the new belt won't last long.slip the belt over the motor shaft then put your roller brush through the new belt.you might have to pull forward on the roller to get it in place because of the new belt ,they are a little tight at the beginning.then alighn your roller ends and put the roller back in their slots.turn the roller by hand till the belt in in the middle of belt guide on the roller .now you can put the cover back on .then your in buisness.
Apr 10, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover windtunnel vacuum belt
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
Aug 19, 2008 | Vacuums
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
49 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
