Question about Canon XL1S Mini DV Digital Camcorder
"DV IF" Flashing
Just started a job that uses a Canon XL1s. When I turn it on the red tape icon with a slash keeps flashing and just to the left and below the battery is another flashing icon that I can't make out. Below that in flashing white letters is the message "DV IF."
I tried to run a head cleaner cassette, but the camera won't do anything. Any suggestions would be appreciated.
To get rid of the DV IF flashing go to >menu>systems>DV control ...OFF. (page 63 in the instruction manual)
Posted on Nov 28, 2008
    Problem Solver:
  • 8 Answers
I had the same Problem red flash and DV IF flashing, so i pressed eject and then pressed in the tape slot manually then closed the tape door. works great again!
Posted on Feb 23, 2010
Hi
Had same problem all I had to do was buy a dv head cleaning tape about £5.00
just had to play cleaning tape for 10 sec and fixed hope its same for you
Olly0404
Posted on Mar 24, 2008
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
Have an IX1s Canon camcorder. Flashing red screen icon.
it means a particular battery is low or out of the camera, which hold the date and time memory of your videos. don't worry it doesn't affect your any recording or playback of videos. I have one and is blinking from past one month. no issues at all.
Dec 06, 2009 | Canon XL1S Mini DV Digital Camcorder
Flashing red icon in viewfinder,looks like a battery symbol with a bar through it ? but camera is working fine ?
You need to change the battery that powers the internal clock and holds your settings.  The slot is on the underside of the grip.
Oct 25, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Mar 04, 2009 | Canon XL1S Mini DV Digital Camcorder
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Flashing battery icon then shots down
Change the lithium battery for the clock. It is found on the bottom of the camera. It is usually a CR2016, you can find it at any where watch batteries are sold
Nov 25, 2008 | Canon XL1S Mini DV Digital Camcorder
Flashing icon
I just fixed mine accidentally... Try this: with Camera on open tape deck, then manually press in the tape cartrige till it clicks in and you hear the tape gears turning then close the tape door last. email me if it works for any of you. lbclassics@gmail.com
Nov 27, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
No tape icon when the tape is installed
Alot of times dirty tape heads can cause this issue. Try loading a Digital Head Cleaning Cassette into the unit, and let it clean the heads. Many times this will solve the problem. Also, make sure it's not the 'wet-type' cleaners, as this will cause damage.
For the record issue, make sure the tapes do not have the prevent erasure tabs set - this is on the bottom of the tape, and is looks like a tab that says ERASE OFF or SAVE.
Not much else that can cause this issue. Never force the tape into the unit, and never hit the unit to get it to work. If nothing works, then I would suggest taking into a service center for diagnosis.
Hope this helps some.
TWEAK A/V LAB
Jul 29, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
887 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
