Monitor/display when i turn my monitor on the button will show green for a couple of seconds then turn off. do i need a new monitor?
    Genius:
  • 1,027 Answers
The monitor is not receiving a video signal, normally this is a sign that the inverter is bad. There are some places that can repair this for about 80.00 plus shipping both ways. Unless your really attached to it 17" lcd's new are about $165.00
If your are good at disassembly and reassembly the monitor comes apart fairly easy and the inverter runs about $ 20-$35 .
Posted on Mar 07, 2008
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
Monitor stops showing desktop
probably needs new voltage regulator for backlight. it would probably be cheaper to just buy a new monitor
Aug 14, 2009 | Acer 22" X223w LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor ACER 24" stop display after few seconds
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Apr 10, 2009 | Acer X241Wsd Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
715 people viewed this question
Alun Cox
David Payne
David Payne
