Question about AFG Daphne Crib
Lost parts need brackets for the back rail both sides and the front slide rail, right side lower bracket. got this used please help. can e-mail at nch_kesh@yahoo.com
Go to www.afgbabyfurniture.com and you can order what you need. Mary
Posted on Dec 21, 2008
Is there a fuel filter on the frame of a 1981 chevy silverado
Yes, generally on the inside of the frame rail on the side of your fuel tank.
Sep 07, 2011 | Chevrolet 1500 Cars & Trucks
I have a fisher and paykel dd24ph6 model that will not lock. Where is the locking mechanism located?
the way the dish drawer locks is the lid lowers onto the drawer..on the sides of the drawer are motors that lower and lock the lid into place ..to get to them the drawer must be removed,to remove the drawer remove th pins from the side of the drawer,slide down and off the front panel and push and and release the tabs that lock the drawer to the slide rails..then push the slides back slightly and lift off drawer..on the sides connected to support bracket on each side will be a lid motor. It is advisable to replace both at once
Aug 24, 2011 | Fisher and Paykel DS605I Built-in...
Need assembly manuel for Jenny Lind 012614 where can I find it online?? Every website takes me to another I am very frustrated....didn't think it would be such a ordeal to locate a manuel online???? Is...
Evenflo Jenny Lind Crib has been recalled.
When you call to get the kit to fix the problem (800) 356-2229 you could ask Evenflo directly!
Here are instructions without a manual...
1. Lay the headboard on the floor in front of you with the bracket holes and model number facing you. Use 2 ¾-inch wood screws to attach the L-bracket and the latch bracket to headboard. The L-bracket has 3 holes and attaches to the holes on the lowest section of the headboard. The latch bracket only has 2 holes and goes directly beneath the metal bracket for the mattress that is already attached. It should face toward the center of the headboard. Once you're done, complete the same procedure on the right side of the headboard. Then do the same for the footboard.
2. Stand the headboard up so you can attach the rails to it. First, place the cross dowel (the small piece of wood with a hole in the side of it) into the hole on the underside of the top rung of the rail. Then put a second dowel in the top side of the bottom rung. Line the left rail up with the headboard at a 90-degree angle, placing it in the brackets you just installed, and insert a 2 13/16-inch machine screw into each of the 2 holes on the front side of the headboard (the side that will face outward). Tighten each screw with your screwdriver until it hits the cross dowel. Then turn the cross dowel clockwise to lock it in. Do the same for the right side and then for the footboard.
3. Slide the mattress platform (the bottom of the crib) into the stabilizer rails (easy to distinguish, since they are the same size as the sides of the platform), putting the longer ones on the sides and the shorter ones on the ends. It will slide in easily. Use 5 ¾-inch screws to attach the hanger brackets to the corners of the platform. The holes are predrilled and you can only put the bracket on one way to match them up, so there is little worry that you will attach it wrong.
4. Put the support brackets (the straight, flat ones) on top of the predrilled holes in the underside of the stabilizer rails. Screw them in with ¾-inch wood screws. Then place the hanger brackets in the slots that were preinstalled on the headboard and footboard. Choose the level that will suit you best. Evenflo recommends the top two for infants.
5. Snap a caster (the round disc) on the bottom of each foot of the crib. Check that all your screws are tight to keep your baby safe.
Jan 29, 2011 | Evenflo Jenny Lind Crib
Where is the battery located?
Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
Nov 28, 2010 | 2007 Pontiac Solstice Convertible
How do I assemble a Bassett crib model 5096-0505? I think I have all the parts. this includes a headboard, footboard, spring mattress support, mattress, two long iron rail support brackets, two sides, four...
where's the manual?
you can assemble it immediately!
have u lost the manual?
you can find the manual here:
Please use the form below to send us an email.
Infant furniture questions to juvenile@bassettfurniture.com
hope you could come to this sites there are many related manners all about mattress:
http://www.bestmattressreviews.com
Dec 06, 2009 | Bassett Mission Crib
Dead battery
Removal Procedure
Remove the battery.
Oct 15, 2009 | 2006 Pontiac Solstice
I have a bad ground wire somwhere on my 2000 monte carlo ss, where are the ground wires located?
G100
Battery cable, negative cable, RH side of engine compartment to the RH frame rail
G101
Left side of the radiator support
G111
Top right of the engine, below the ignition control module
G113
Lower LF of the engine, on the automatic transaxle stud, near the starter
G151
On the left frame rail, forward of the left front strut tower
G171
On the left frame rail, right of the left front strut tower, rear of G151
G201
Behind the I/P, on the LH side of the brake pedal bracket
G202
Behind the I/P, in the center
G203
Behind the I/P in the RH side of the brake pedal bracket
G301
At the base of the LH B-pillar
G302
At the base of the RH B-pillar
G309
On the RH side B-pillar
Aug 11, 2009 | 2000 Chevrolet Monte Carlo
How to install rear end on firebird 1995
It sounds like you broke your pan hard bar, or it's mount. If this has happened you need to check your lower arms also to make sure they did not get bent in the process. The pan hard bar extends from the rear axle housing to the frame, wich is braced to the opposite frame rail. I would think if it or the mounting bracket is bent or broken is should be pretty noticable. You will have to look under the car at the back side of the housing, in front of the gas tank. You may need a flashlight to see up to the frame rail bracket.
You can try a Camaro/Firebird "club" type web site to help find pictures. I do not know of any right off hand.
Good Luck,
Richard
May 20, 2009 | 1995 Pontiac Firebird
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
Model 680
you can use wood to carve one, it is not too hard especially if you have the right tools. I was also looking for the same parts, and the sliding rail. I did not find it and had to make one with a piece of wood.
Nov 06, 2006 | Kinderkraft Vermont Crib
AFG Daphne Crib Logo
103 people viewed this question
Top AFG Baby Gear Experts
Dorel UK
Dorel UK
Are you an AFG Baby Gear Expert? Answer questions, earn points and help others
