Question about Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 Washer does NOT spin (coupler is fine).
My washer does everything but spins out at the end. Over a months time I noticed it not spinning very well here and there and I've even smelled what seems to be rubber burning. The last few times I've used it I have had to help it along in getting the spin cycle to go but it's pretty much done now.
I've searched and found similar problems online but when my husband took the machine apart we found;
the coupler part was fine.
we replaced the dog agitators
there was a faint spraying of grease around the inner wall of the washer casing.
From here we don't know where to go. Local repair shops want an arm and a leg to repair/home visit. I can't believe after only 3-4 years this has to be replaced???
Any help is much appreciated.
  • partyof5 Mar 09, 2008
    just wanted to follow up on this...
    we found a reasonable handyman and our washer was repaired. it seems the seal was broke around the trans. which leaked grease into the clutch. a new seal and one clutch later it is working like new.
    President:
  • Kenmore Master
  • 2,651 Answers
Oil around the inner wall of asing sounds like a transmission assy( ck your manual should have a 5 yr part warr on gearcase)
Posted on Mar 07, 2008
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
My 70 series Kenmore washer will not spin
REPLACE MOTOR COUPLER/ IT FIXED MY WASHER SAME PROBLEM, DIFFERENT MODEL. HOPE IT HELPS YOU.
Feb 03, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
203 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
