NO SIGNAL FOR SAMSUNG TV
We have a new 932MW SAMSUNG TV to be used mostly for gaming. I've connected the Power Cable and XBOX Cables as per usual but NO SIGNAL is appearing on the TV screen. I'd appreciate your help.
Thanks
Thomas Manning Age 11
  • gatorgirl50 Dec 02, 2008
    I have a Samsung LCD Tv model LN40A650A and the screen keeps saying NO SIGNAL. Everything is set up properly and the set worked fine the night before.
  • 13 Answers
SOURCE: RCA d52W19Byx1
Check to standby voltages, the three of the five and a 7.5 voltage going to the SSB main PCB if these voltages are there most likely have no horizontal drive.  You'll need to replaced the SSB part # 264120. I recommend that you have an authorized RCA servicer replaced the board, convergence data needs to be uploaded to a computer via a chipper checker.  Because a full convergence is quite difficult.
                                      Packman
Posted on Oct 29, 2007
ChadL777
  • 69 Answers
SOURCE: Emerson LCD HDTV 19 inch won't connect to Xbox 360
Im not an expert on the 360s, but I believe there is a switch or option on them to play them in HD feed. They must be set to play HD as far as I understand.
Posted on Dec 26, 2007
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
  • 195 Answers
SOURCE: samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Posted on Nov 10, 2008
SOURCE: "NOT SUPPORTED MODE" when using my xbox 360
If you got that while playing it sounds like its your GPU melting... when the older xbox360s get hot the circuit starts to warp and sag in the middle.. the causes the GPU to seperate from the board which gives you wierd or no graphics... ppl suggest "the towel trick" wrapping you xbox in a towel to overheat it in hopes it will reconnect the GPU.. otherwise there is very little you can do.. just hope MS will repair it for you or buy a new one.. i have the same problem at the moment with my friends old one.. so im currently working on a solution.. will try and let you guys know if i find something that works...
Posted on Jun 13, 2009
What cables do I need to plug my X Rocker Chair model #51231 into my Xbox 360?
You need to go buy another cable, get a good length RCA Audio Red White Cable 2 Male To 2 Male one that suits the distance between the chair and the xbox.
Then you need to get a Hosa GRA101 RCA Female to RCA Female Coupler Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
May 31, 2012 | Pyramat Sound Rocker Gaming Chair
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
My screen rolls whenever i hook my xbox up through the component cables and try using the hd output on the xbox. works fine when switch on xbox cables is set on tv.
You need to set XBox resolution to 480i. That is the only resolution it supports, if it can supp rt that. The Component connection is intended for a DVD player and not necessarily game consoles as it only support 500 lines per second.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Samsung TXN2726 27" TV
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
XBOX 360 will not display on my TV NOW!!! HELP!!
Sometimes cables will just go out, especially standard ones that come in the box on gaming consoles, DVD players, etc. My recomendation would be to narrow it down to either a problem with the XBOX, the TV, or the cable.
Step 1: Find a friend with another TV to try the cable and console on. If this works, we can automatically determine that the problem is with the TV, however it most likely isn't.
Step 2: If you know someone with an XBOX, take your console to their house and connect it to their TV with their functioning cable. If this works, we can rule out the gaming console.
If Step 1, 2 yield no results, then the problem most likely is with the cable. You can pick one of the up pretty cheap on Ebay, Buy.com, etc. However, I would recommend going with an HDMI if you get to this step. You will experience much higher quality picture, sound, etc, and have a much higher gaming experience than before.
Apr 13, 2009 | Samsung LN-T4665F 46 in. LCD Television
Xbox 360 wont play
cheapest option is to check your cables are in the right sockets on xbox and tv, a crossed cable would result in no signal.
if in right sockets next would be to try different cables to check if yours are broken.
borrowing would be cheapest.
new cables would still be cheaper than any problem from inside the xbox.
Feb 23, 2009 | Dell PWR,SUPLY,150 WATT,PUSH BUTTON...
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
