Panasonic PT50LC14 dark picture
I have a panasonic pt50lc14 that has a dark picture. I have the brightness turned all the way up and some other settings out of adjustment to compensate and the picture looks good in hd but when watching regular especially if the picture is stretched it looks terrible. While replacing the lamp I noticed that the piece that the lamp shines through (I'm assuming it seperates the colors) appears to have a layer of dust at the bottom and was wondering if this was causing my problem and if that piece can be removed to clean as it is sealed ?
spqr163
  • 37 Answers
SOURCE: where do iget a ballast for a panasonic pt50lc14?
my recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Posted on Mar 12, 2009
  • 159 Answers
SOURCE: reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Posted on Sep 21, 2009
ladywinn
  • 5138 Answers
SOURCE: my panasonic pt50lc14 says the air filter needs to
It means clean out all dust and dirt blocking Airway, yes you can do it yourself take small paint brush and remove debris.Clean off and around Lamp for starters, all Fans that may have dust and dirt on them.
Posted on Oct 04, 2009
  • 380 Answers
SOURCE: how do i replace the lamp for my panasonic
Pull the front off and you'll see the lamp compartment. Loosen the one screw and the lamp door with come off and look inside. Loosen the 2 screws holding the lamp then remove.
Posted on Dec 15, 2009
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tip
I hope that helps.
on Apr 30, 2010 | Televison & Video
Need to reset lamp hr. meter on panasonic pt50LC14 tv with out the remote
Unfortunately you might need the remote. Otherwise up is channel up down is channel down left is volume - and right is volume +. Enter is the input/source button. A new original remote can be purchased here http://www.replacementremotes.com/Panasonic/Buy-EUR7603ZB0-Remote-Control.html
Feb 08, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Where is the lamp of panasonic pt50lc14 located at?
Lamp is located under lower front cover as shown in below image, pull that lower front cover and you will see lamp cover tighten with screw.
Remove it and lamp is there.
Feb 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do i replace the lamp for my panasonic pt50lc14
Dec 14, 2009 | Panasonic PT-56LCZ70 56" HDTV
Reset hour meter for replaced lamp
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
